connecting cd 3.5 to NAC 72
Posted by: Robin W on 31 August 2003
Help please. I've just purchased a NAC 72 [1990 model]without a dedicated cd Din socket I was advised to use the tuner circuit[ which works ] however after reading information about board pulling to improve the sound I'm now confused,I have removed the following boards:- 2 x 322[phono], 2 x 324 [tape loop]the info says to remove the 2 x 328 boards on the Aux circuit and replace them with 326 link boards, this will clean up the sound BIG TIME, however the Aux is fitted with 2 x BNC sockets I understand adaptors are available to convert them to RCA. THE BIG QUESTION
has anyone carried out/ modified the cd circuit as above using the Aux BNC circuit and fitting the 326 boards, was there any improvement/benefit gained than using the tuner circuit. Hopefully someone will help me to decide
Thank you
Robin
Thank you
Robin
