Naim DAC - part 2
Posted by: james n on 08 July 2009
Well i managed to slip out of work and i've seen the DAC myself now - i've been very interested given my front end is computer driven. I was quite lucky to get there early and so had the dem to myself. Unfortunately my dealer had laid on some live music. Just a girl and a guitar and she was superb and set a standard that the systems i would hear couldn't really compete with - i could have stayed and listened much longer but the DAC was calling...
Lets get the speakers out of the way first. Good looking and some very interesting design features. Sound, well the room wasn't ideal but i thought the Ovators had too much bass - almost like a badly adjusted sub. Mid and treble good though - very clean and detailed without harshness. This was driven via a 555/552/500 system.
Next up the new CDX2 with its switchable S/PDIF output. This sounded good, in fact i thought the Ovators bass was better on the end of the CDX2, mainly as the 555 goes so deep it wasn't doing the speakers any favours.
Onto the DAC - This is quite an assuming box as most have you have seen. Inputs are 4 Toslink, and 4 Coax - two of these are via BNC the other two RCA. Audio output is via DIN or RCA and there is the Burndy connector to allow PSU upgrades. USB connectors on the front and rear for an iPod or memory stick.
Internals - Jason explained that Jitter had been eliminated on the S/PDIF interface by clocking the data into memory and then clocking back out into another buffer which is synchronised to the internal clock - nothing very new there although i'll await the white paper with interest to see if Naim are doing something innovative with regards to jitter reduction.
The sound - well it was (to me) better than the CDX2 - voices had more presence more detail and the music flowed better. How good that it is i don't know - its better than the CDX2 but does that mean the DAC is a lot better or the standard CDX2 output stage isn't that hot. I'm sure that is not the case and for any CDX2 owners it'll be a decent upgrade with the option to add a PSU for further sonic pleasure.
The other thing the DAC does is that it'll play files from a memory stick and iPod. I'm a bit confused on the iPod side of things as the iPod is connected via the USB connector - Wadia connect to the Dock connector to take the raw digital data out of the iPod. As i see it (and i may be wrong), i'm not convinced that the DAC is 'doing a Wadia' - its just playing files from the iPod with the DAC providing 'transport' controls as i'm sure the USB interface wouldnt support raw data unless its in a proprietary format and the DAC is doing something else with it.
I was dissapointed to see no computer driving the DAC as with perfect jitter reduction it shouldnt really make a difference - Jason explained that the transports would sound different - but at this point i'm not too convinced. We then got onto computer ripping but again my own findings are different.
So is the DAC for me ? - well probably not. I'm not convinced by a fancy S/PDIF interface as being a good option for computer audio. The iPod connectivity is probably useful but seems a bit of an afterthought. I'd also need to hear it in my own system - the room, system and music was unfamiliar so no point of reference for me. As a digital hub in an all Naim system and an upgrade to HDX/CDX etc i'm sure it'll be a winner.
James
Posted on: 08 July 2009 by John R.
This was a very good show report and finally some more facts. Did the officials say something more about playing music from a memory stick? I would love to put some high resolution WAV-files (24 bit and high sample rates) on a USB stick and play them via the DAC without a PC or Mac! Any information about this would be very much appreciated as Naim seems not to be able to post a few specs - they seem to prefer wild speculations.
Posted on: 08 July 2009 by QTT
So it would be alright to hook up a Mac Mini to the Naim DAC via an optical toslink with a mini plug?
Posted on: 08 July 2009 by pcstockton
So it is confirmed that while the DAC has USB connectivity, it is exclusively for an iPod or Flash Drive? ... and this means it CANNOT be used as a USB "audio device" that can been "seen" by the computer as seemingly all other USB DACs are?
This is seriously disappointing to me.
It is very odd that Naim has developed this DAC for sole use with the HDX or the CDP line. Especially when you consider the rampant use of a PC/MAC front end, and the widely popular media players we have come accustomed to, and demand use of.
To need to add a TC or other USB-to-Digi converter in order to use this with a computer introduces variables I dont want to play with. I am already there now.
Unfortunately waiting a year for this info has proved to be pointless and frustrating.
The new DA-11 is now looking MIGHTY attractive. Sorry Naim. I waited and waited and waited. I should have assumed that my particular needs would not be filled by Naim. And I am trying not to bitch about it. I am just let down I suppose.
On to bigger and better things. A Naim source is not for me I guess. Well, Ill snatch up a nice used/exdem CD5i as soon as the new line of CDPs drops. It is a great player. But for 99% of my listening, i guess Ill have to look elsewhere.
Sincerely,
Bummed
Posted on: 08 July 2009 by T38.45
Thank you james for reporting! do you think the hdx+dac+xps will sound better than hdx+555ps? rgs ralf
Posted on: 08 July 2009 by garyi
I feel a bit silly but I still cannot work out how one picks files if its on a USB stick?
Posted on: 08 July 2009 by james n
John - i didnt really enquire about the way files are played off a stick. I presume if they are in an 'approved' file structure then the front panel controls will allow track selection.
Patrick - i'm not 100% sure on the USB front whether it could be used as a USB audio device but it wasn't mentioned. I felt Computer audio was seen as a poor source compared to a CD transport or HDX (not suprisingly). I agree with you though - its dissapointing that its not supporting computer audio via another interface. Firewire on the Weiss has been a revelation.
QTT - yep that would work.
Ralf - i didnt get to do that comparison so i cant really comment.
James
Reminds me of my original iPod shuffle - guess the track
I could use this DAC with a soundcard or USB converter but I am not going to go down that path. again. It must be a computer DAC.
Wouldn't the application of using the DAC as a "soundcard" have more relevance than connecting an iPod?
Guess not.
This bloody sucks.
I now wait for the Naim DAC versus Lavry comparisons.
Thanks for the updates James. We all appreciate it, despite it being bad news, in my eyes.
-p
Posted on: 08 July 2009 by goldfinch
James
I also think spdif is not the best interface for computer audio. It seems this DAC is not designed for computers, I have waited for a year for the Naim DAC, I even upgraded to a 555PS for my CDX2 thinking about using it with the forthcoming DAC!,
if only Naim would launch a streamer for the DAC...
Guess not.
This bloody sucks.
-p
Computer DACs via firewire or asynchronous USB are the perfect match for computer audio but using a good audio device could improve the performance at a cost. The problem with the Naim DAC is it lacks the most common interface used by the best sound cards -AES/EBU-.
That is probably next... More and more and more boxes.
Imagine a Naim Streamer, upgradeable with two 555PS.
So in order to do what most require, we all need to buy an HDX, a Naim DAC, a slew of power supplies, and a third party option for streaming? and a NAS most likely....
It makes sense from Naim's perspective to not make a USB DAC now that I think about it. Mo' Money!!!
In the end, maybe whilst alienating most of their current customer base with the new speaker line, XS whatnot, and strange approach to Distributed Audio (HDX, UNiti, DAC), they will most likely summon many new potential customers down the line. One's without preconceived notions of what they want or expect from Naim.
Not personally interested.
Posted on: 08 July 2009 by PMR
If all true, that's a shame.
Let's hope the final box is not just another CDX/Naim plug-on, but a DAC that is rather special in order to compete with the Lavry, Benchmark and Weiss. Having spent a good deal of time with the Naim CDX-2, the Naim DAC will need to be quite a step forward in order to be in the above mentioned league IMO.
Posted on: 08 July 2009 by DHT
I sincerely hope Naim re-think this product, It appears to be nothing more than a rather feeble sop to the ipod .
It sounds pretty good to me. Maybe some additional async USB and firewire digital inputs would be perfect.
They have obviously abandoned this market. No big deal, although I wish I knew this was the approach a year ago.
It makes sense though that no one spilled the beans regarding its design. Doing so would have only made people seek options elsewhere sooner. This way Naim keeps everyone looking to them for as long as possible.
I guess I forget that this is all simply business. Profitability, brand awareness, market share are all far more important than ensuring we do not wait for a product that is never coming.
I am sure they are very intelligent business people first and foremost. It must have made much more fiscal sense to approach the DAC this way.
It is curious though that they couldn't approach the DAC in the same manner as the Superline which seems to be a fairly ubiquitous product used by Non-Naimers.
I cant see the Naim DAC selling to non-Naim system owners. Wouldn't they rather buy a DAC that is "matched" to their transport?
Yes obviously.... that is what we are talking about here.
But not going to happen it appears.
Posted on: 08 July 2009 by js
Nothing's for everyone but I'll be quite happy with a $300 TC firewired to my lappedtop
when I need to use a PC...depending on the overall performance. TC can take a firewire drive in the chain to store files that can be controlled by the laptop so no need for more than the quick laptop firewire plug up to play a large library even without ethernet. An ethernet cable or wifi allows the system to play from anywhere in a network.
Not what some will want but I tend to find a way to make things work for me if I like them enough. That part remains to be seen. The interface was never going to be a deal breaker for me. Can't please every one.
I'm also still a bit baffled by the Ipod/Iphone thing as I wasn't aware they could stream via a standard USB. We do know that the DAC has a player and that you can play Ipod files via usb through Itunes. It's not that far fetched to think that there are ways to do this unconventionally though conventional streaming would seem more likely.
It appears they did re-think it, and somehow the vocal majority (ERRRRR marketing dept) has requested iPod connectivity over Computer connectivity.
Really though, now that I ruminate on such issues, why would they make a computer DAC, or even incorporate the option, if they are trying to sell Unitis and HDXs? Seriously. I should have seen through this a long long time ago.
If the DAC is an upgrade to the HDX, why would we not all cut our the middleman?
Green lit DA-11 it is.
JS,
How many people have Firewire on their PC? Im not buying a PCI card just for that.
To me it makes far more sense to have a USB DAC that handles the conversion rather than 2 or even 3 other products.
It just introduces more variables that will be suspect.
Certainly not. But i have yet to read how anyone is pleased by this exclusion, and cannot imagine why one would be.
No one seems overly giddy about the Ipod crap.
This DAC is intended as an add-on for the the HDX and the new range of CDPs.
Someone at Naim leaked the info about the external DAC's existence in the first place. Why couldnt they have also mentioned it was going to be designed to work with the HDX and new range of CDPs??? Oh right.... they wouldn't want to risk losing CDP sales with mention of a new line of CDPxs. Many would have simply waited. In waiting Naim risks losing the sale to the competition.
Not caring about losing market share/sales to all of the other external DACs with USB should have been an obvious omen.
If Naim had released the info about what the DAC was really intended to be they would have shown their hand and lost sales in the interim.
Seriously, who in the last year would have bought any of the Naim CDPs if they knew that a DAC was coming out that would be a upgrade to the internal DAC. It would have been obvious that a new range was coming.
I dont even know why I care at this point. Ill stop thinking about it.
To many forum members relief, I most likely wont be spending much time over here in DA.
Back to concentrating on the rest of the kit.
Not just for better music?
The cards are cheap, easy and lots already have firewire. Both my PC and laptop had it. There are already so many variables at a USB out. ASIO or not. Rips. Player. etc.
MAC/Amarra or PC/ASIO to a TC will give VG repeatable results without much complexity if a computer is what you want to do. Like I said, not for every one but if the DAC is special, I suspect many will find a way.
It's clearly not just for their front ends but of course it's an important aspect. It's a DAC that does a bit more. I would have been fine without even the bit more as long as it sings. AES/EBU is easily converted down passively without adding jitter etc. None of these are big issues unless you personally view them as such and all are allowed to have that view too.
I fully understand the feeling of those here that are approaching this as 'It isn't for me unless it forces me to buy it by being that good'. We'll all have to wait and see if it is.
Not being pejorative here but... is it?
I am there I suppose. But it will have to take my head off the way the HDX did.
Maybe its time for me to go retro and bust out all of the CDs, get a CD5i, and do it the way I had for 20 years prior to buying a little WD drive.
Just need to buy some shelving.
I haven't heard it.
Posted on: 08 July 2009 by SC
Thanks for the write up James.
Interesting to read yet another lukewarm response to the Ovaries....It seems as though every report from these road shows is peppered with 'perhaps the room wasn't ideal' as an excuse, which I must admit makes me scratch my head and is becoming rather funny...All seems arse about face to me...I thought the aim of the new speaker range was to be generally more appealing, user friendly and to reach out to a wider audience than in the past - but, it seems, the room has to be 'perfect' !
As for the DAC, it just gets weirder and weirder...I personally couldn't give a toss for the iPod facility - nice if it's there, sure - but it really isn't why I would be purchasing a £2k DAC. Surely this territory & market covered by the Uniti. It's great that the HDX and new CDPs gain a noticeable improvement with the DAC (although I still have something of an issue as to why it takes a £2k addition to do so) but I really feel it's becoming increasing narrow minded to leave it there - Naim have an opportunity here to release a killer product (much like the Uniti is being received) but I can't help feeling someone or something has the hand-brake on....As I have written elsewhere, to tour a DAC around on demo and yet not use or even mention a computer source just seems, well, daft...
Computers are where we are going (and arguably we are here now) and DACS are becoming the audio central HUB to all of this.....It just seems that in Naim's world, the DAC is merely another upgrade box for your CDP and whilst that's great (I'm sure it sounds fantastic) it's also short sighted....
I personally would have like to have seen 2 DACS released. One, at around the mark we are looking at here, designated for 2 channel audio. Coax, Optical, USB (streaming) inputs. The 2nd, perhaps for £1k+ more, would be the same but with the addition of DD & DTS HD surround processing. HDMI in & Out added to the rear. Presumably a small front screen would be needed (or, supply of a decent remote).....Oh well !
