Is there somewhere official infos about DVD5 software updates ?
Posted by: karyboue on 05 August 2005
My second DVD5 still has that very annoying bug : http://forums.naim-audio.com/eve/forums/a/tpc/f/780...082917996#4082917996
Almost everyday I have to reset the machine ...
I believe that some day there should be a software update ... but is there somewhere on the Naim website any official informations, follow-up or whatever about software updates ? ... that day I could run to my dealer ...
(My dealer received DVD5 software update but it is not suppose to concern my too recent 218xxx buggy DVD5.)
Posted on: 05 August 2005 by niceguy235uk
The dvd5 software updates are supposed to be for all players. mine is 219xxx and still had the old software so i would go back to your dealer and check it out.
The procedure for the update includes a task to check the version you actually have at the moment in your player. You can then continue with the update.
Get on the phone...
Jason
Posted on: 05 August 2005 by karyboue
Thanks for the info Jason.
I'll see that with my dealer and hope it will solve my sync stuff on RGBHV.
I also hope that Naim will let us know directly when they launch new updates.
Posted on: 06 August 2005 by SimonJ
Mine when I first bought it had the old firmware and had the problem, but within a few days of buying it my dealer receieved the new firmware and updated it and it no longer happens and comes out of standby fine every time.
