HDMI cables : really work?
Posted by: Nuno Baptista on 26 September 2009
Do you believe that a brand cable HDMI improves the TV image ,or is it non-sense spend 60€ on an IXOS HDMI 1.3,for example?Some guys say that´s all 0 and 1,and even an expensive cable doesn´t improve the TV colours
Posted on: 26 September 2009 by winkyincanada
My understanding is that for short lengths it makes very little difference. For longer runs, higher quality cables might offer some advantage.
Posted on: 27 September 2009 by tonym
Cheapo HDMI cables are a really bad idea - they cause all sorts of problems.
There's no advantage with the really expensive jobs, just get a good quality one from a reputable brand.
Posted on: 27 September 2009 by Nuno Baptista
The IXOS has a 35€ cable entry level,a 60€ and a top 110€.Do yoou think the 60€ is OPK,or should I choose the 35€ entry level?
Posted on: 27 September 2009 by Former member
Nuno,
Can you try both the 35/60? and let your eyes tell you.
Stu
Originally posted by munch:
Nuno,
Stu
OK,good idea!I think I can
What problems do they cause? My understanding is that, if they meet the HDMI standard, they're fine.
They dont cause problems.
Its just they are no better for shed loads more money.
How would you actually know if a cheapie unbranded HDMI cable was made to any particular standard? Such cables are sometimes guilty of causing picture and sound dropouts. The quality of the connectors and cable is often very poor, reliability is poor.
One thing to note - the claims made for better picture quality between the various cables are rubbish - the picture, provided it's being transmitted by the cable, will look exactly the same.
When i got my n/VI when it came out.
I rang Adam when he was still at HQ to ask him what cables Naim used.
They were the cheapest you can find in any computer shop.The name began with a M.
Stu
Posted on: 28 September 2009 by Richard Dane
Stu,
if you're referring to the DVI cables then, yes, we tested a whole load of different types, brands, prices, and found our favourite to be a relatively modest cable made by a swiss company - it was relatively cheap too! I seem to recall the name started with an "R"... Rolex? (nothing to do with watches) I've got one at home,I'll have to check the make when I get back.
Of course, the situation is quite different when it comes to analog component leads. Here, the cheap ones really are quite poor. Best by far was the Naim component lead (of course!) - I still use this in preference to a digital DVI/HDMI lead on the DVD5. It helps of course that the DVD5 has such a superb component output and the Fujitsu plasma I use has an excellent component input (on BNCs too) as well.
Posted on: 28 September 2009 by Simon Matthews
I use a 10m hdmi cable from my blue ray to my projector. When I upgraded to the IXOS cable I felt that picture clarity and colour depth improved when compared to the cheapo it replaced.
Posted on: 29 September 2009 by Eloise
I use a cheep 10m HDMI cable to my projector (720p Hitachi LCD). Compared to the 7m QED cable I used before, the picture quality is very similar (never done direct comparisons) but the cable length is getting to it's maximum as if you use a passive switch you start getting red "dot pattern" interference.
Eloise
Posted on: 29 September 2009 by SC
Richard - Can I ask your reasons for preferring the component connection to the DVI connection from the DVD5 ? I'd be very interested to know the merits of each...
Thanks, Steve.
Posted on: 29 September 2009 by Richard Dane
Steve,
first I must qualify this as it may only be a particular synergy between the DVD5 and the Fujitsu plasma. While the 1024 x 1024 ALIS panel that Fujitsu used is pretty good but probably not as good as the equivalent Pioneer, the electronics, processing etc.. used by Fujitsu were of a very high quality with a great deal of care to detail. For example, the fact that Fujitsu bothered to use BNCs on the component input (5 no less, with separate H and V signal) tells you that the analogue input was much more than just some legacy feature.
Overall, while the DVI connection is very good indeed, and slightly sharper overall compared to the component, the latter had greater depth, smoother edges, better skin tone (a real Fujitsu strength) and an overall more film-like image. Overall, I preferred it to the DVI. Not just me either, but anyone else who did the comparison. Bear in mind though that I am using the Naim Component lead with 5 BNC - 5 BNC connection. Compared to other high quality component leads, the Naim one is something rather special.
The Fujitsu may be over 5 years old but I still have no wish to change it. I have been tempted by one of the Pioneer Kuros but the Fuji still has some strengths (and build quality is so much better than current offerings) that I would hate to lose so it stays. It's great with hi def too although limited to 1080i, which I think is perhaps not too much of a limitation really...
Many thanks Richard. Interesting to read your findings...
I'm considering picking up a DVD5 (mostly for DVD-A use I must say), if I can find a good one, and indeed do already have the Pioneer 500A...It would be interesting to test the two connection options on such a new panel...
I fully understand your description of the 'feel' you are getting on your Fujitsu through the component cables - a typical analogue vs digital debate it seems. I'd be curious to see if it holds true on the Pioneer, or if the added sharpness from the DVI is more attractive...
I'll have to see if I can swing a demo of the Naim cable come the time...
By the way if you are tempted by a Kuro, you'll have to hurry, there's not many left these days ! To be honest, I'd tend to agree that, excepting the Pioneer, there's probably not much out there to touch what you already have...Surprisingly, at the top end, I don't think the panels have advanced all that much in the last year or two...I think my next TV will be a projector !
Cheers, Steve.
Posted on: 29 September 2009 by Former member
Richard,
I think it was Molex Winker
Steve,
DVD-A via the DVD5 can be absolutely superb. Whenever I have been in the US I have searched out the elusive DVD-A releases and always end up buying the CD + DVD-A versions of any new releases - particularly Neil Young (good thing I'm a huge fan really..). I'm so pleased that Porcupine Tree continue to offer DVD-A versions of their releases as well.
Munch, the make of the DVI cable is Roline, not Rolex (or Molex, although I do see they make cables)!
I agree Richard !
I recently got my hands on an 'unopened' copy of Fleetwood Mac's Rumours DVD-A - I'm dying to listen to it but I'm saving it until I have the system I want...!!
Posted on: 02 October 2009 by paulr0414
The only problems I've experienced with HDMI cables have been with the more expensive ones. Start cheap and ask your dealer to demonstrate the advantages of more expensive is my view.
Posted on: 03 October 2009 by tonym
The only problems I've experienced with HDMI cables have been with a cheap one. the terminations of such cables can be extremely poor and can cause a variety of strange symptoms.
As with everything else in life, you get what you pay for!
Posted on: 04 October 2009 by paulr0414
Actually, you pay for the packaging. The vast majority are made at the same workshop.
Posted on: 04 October 2009 by tonym
Sorry, that's complete bollocks.
Just check out the quality of the plugs on the ends. Take them apart if you're really curious (I have, incidentally) & look at the way they're terminated inside. Buggers them of course, but you'll be doing yourself a favour with the cheapo ones..
Posted on: 05 October 2009 by Stuart M
Checkout http://ukhdmi.com/ they have great HDMI cables that are reasonably priced and they work. In addition great service, I had problems with a switch box and they did everything possible to get it fixed. Highly recommend.
Posted on: 05 October 2009 by Former member
Originally posted by Richard Dane:
Steve,
Richard,
I have been back and had a look at my paperwork for 2006 and it was Molex HDMI cables Naim were using at the time.
Stu
