Cartridges to Minimize Surface Noise
Posted by: Markus on 02 February 2004
From personal experience I've learned that different cartridges convey different levels of surface noise. For example, my Goldring 1042 conveys more noise than the ancient Shure M93E in my Pioneer PL41, even though the Goldring is mounted in my LP12. Certainly I've previously found that the LP12 with Ittok seemed to convey less surface noise than other tables I heard around the time that I chose the Linn.
I've also found that my not-expensive Stanton Groovemaster II dj cartridges are less troubled by surface noise, even though they're used on comparitively low quality dj turntables like technics and numarks.
My guess is that this livability can be attributed to two main causes--one, a rolled-off high end (perhaps) and two, stylus shape. Both the Shure and the STantons are non-exotic type cartridges.
I'm curious about others experience. Which high-resolution cartridges are capable of excavating the music from the grooves without too much surface noise? Since I tend to collect a lot of very vintage soul 45s and funk lp's, I run across a high percentage of fairly well-worn vinyl. Via the Shure/Pioneer combo, this wear and tear is less troubling than via the Goldring/Linn.
Is anyone else out there collecting/playing beat-up albums? What are people using to do this?
Markus
Markus
