ipod to macbook
Posted by: u5227470736789454 on 01 October 2008
Hiya guys,
I am just wondering if an itouch can be linked to a macbook to control itunes remotely, and if it is possible how do I set it up ?
Barrie
Posted on: 01 October 2008 by pcstockton
Mac Forum possibly might be the place to ask this???
Posted on: 01 October 2008 by u5227470736789454
Sorry if this is the wrong forum, it's just that there seem to be a few mac users in here.
My error
Posted on: 01 October 2008 by garyi
Download the latest '2' software for ipod touch and then the apple remote app both available from the itunes store.
Follow the instructions.
You need a wireless router in the mix somewhere.
Posted on: 01 October 2008 by nap-ster
How remote is remote?
If you mean in the same house then yes you can if you have a wireless network. Simplest option is to get the Remote app from the iTunes store.
good question - remote does mean in the same house Smile
Posted on: 01 October 2008 by Lefty
Yes, it is possible and pretty cool too. Here's a youtube video showing it in use:
Apple Remote Application
Lefty
Posted on: 02 October 2008 by u5227470736789454
Thanks Lefty, very helpful. I am just trying ti figure out how to connect the itouch directly to the macbook, rather that via a seoerate wireless connection ( using airport ???)
Thanks again
Barrie
Posted on: 02 October 2008 by nap-ster
You can't connect directly to use the Remote app. You have to go through a wireless router that both the iTouch and the macbook are connected to.
Thanks Napster I will dig out my Aiport
Barrie
Posted on: 02 October 2008 by winkyincanada
I was having great success with just an AE as both my router and music-server comms thingy. It's a really neat little box. (I've since added a Time Capsule to hold my music files and as easy back-up for everything else).
"Remote" is a great app. Very clever.
Posted on: 03 October 2008 by u5227470736789454
Thanks for all the help folks, it is now up and running, much obliged
