ConFUSED? I am.
Posted by: Analogue on 27 September 2007
Hi,
My wife makes bread using a bread making machine.
On her last attempt to do so she turned on the machine and said machine asked to be programed, which she duley did and then pressed the start button.
Machine then started beeping and showed "Error", tried several sockets - same result.
Anyway the bottom line was that on changing the fuse, normal function was resumed.
IMHO a fuse iether works or it doesn't i,e power or no power?
Thank goodness this fuse was not powering a piece of hi-fi equipment.
