SBL's
Posted by: MichaelC on 03 January 2004
Funds permitting I am tempted to get my hands on a pair of recentish SBL's to replace my Kelidhs. The rationale being that these will compliment future intended upgrades.
A couple of questions though:
1.Can anybody give me their dimensions ie HWD?
2.What is the minimum recommended distance between the speaker and electronics before they begin to interfere with each other?
Mike
Posted on: 04 January 2004 by rch
Hi Mike,
SBL sizes (H/W/D): 885 / 266 / 270 mm.
Minimum recommended distance: 300 mm.
Christian
Posted on: 04 January 2004 by Thomas K
Christian, I think the 30 cm bit refers to the distance between transformer and non-transformer components, not speakers and components. I don't think it would make any sense to stipulate a minimum distance for the latter -- the farther away the better.
Thomas
Hi Thomas,
this data is corresponding to the owner manual.
But I agree with you: the farther the better.
Christian
