n-sub cables
Posted by: Juliandowd on 11 October 2006
Hi,
I am very lucky to get a s/h n-sub for my current system.
Now I-m looking for the correct cables. I need one from n-sub to av2 and another one to supercap (for stereo). What are the recommended cables. Please help.
Best regards
Fred
Posted on: 11 October 2006 by Manu
Naim makes such cables, available in 5m or 10m
The supercap to N-sub is critical as it must not load the preamp. Use the Naim one.
Posted on: 12 October 2006 by Neil Bennett
I got an ex-dem N-Sub a short while ago and went through the same process (although I needed only one, for the AV2),coming to the conclusion that getting the Naim on ewas the best option, although it's expensive.
It works well, although I don't have anything to compare it to.
Neil
Posted on: 14 October 2006 by Juliandowd
Thanx for advice. I´ll order these cables at my local dealer.
Fred
