Unswitched wall socket help
Posted by: bob atherton on 20 June 2009
About 18 months ago we had an extension built on our house that amongst other things is where the hi-fi now resides. I stupidly at the time did not get unswitched sockets installed where the system was going. In the near future I will dismantle the kit and put in two double unswitched 13amp wall sockets.
What make is recommended for this? I’m guessing that it will be Crabtree or MK but I have an open mind. I use a Grahams Hydra at the moment but may consider other mains cables like the Powerline in the future. Thanks
Posted on: 20 June 2009 by FangfossFlyer
Originally posted by bob atherton:
...What make is recommended for this? I’m guessing that it will be Crabtree or MK but I have an open mind. I use a Grahams Hydra at the moment but may consider other mains cables like the Powerline in the future. Thanks
Many people swear by Crabtree, which is what I use, and these can be purchased from Screwfix.
Although I have never compared them against any other manufacturer.
Posted on: 20 June 2009 by bob atherton
Thanks Richard,
One small thing, though nothing to do with wall sockets, is that I made two small typos on my posting 'were and not where', and wished to correct that. I clicked on the edit button and got this message? I thought this is how one changed typos. Any ideas...?
Error
You have not been given the permission(s) to access this page. You require the following rights to view this page: 'Edit/Delete Own Posts'. For a full list of permissions you have on this community, please visit your Personal Zone Permissions page.
Posted on: 20 June 2009 by ianrobertm
Edit only works for about 15 mins, I think.
IanM
Posted on: 20 June 2009 by madasafish
Bob
just done this with unswitched MKs from B&Q. They have a nice 'rounded edge at the top if you're bothered about that sort of thing. Also, they were very cheap.
Posted on: 20 June 2009 by Adam Meredith
The, strangely ignored, Forum Rules have:
"As a member you can make posts – these can be edited for some 45 minutes but cannot (as a peculiarity of the software) be deleted.
If you are unhappy with a post – please edit it down to “PD” (Please Delete) and I will delete it when/if I see it."
Posted on: 20 June 2009 by gone
at last, an ortomatic spel chequer on the forumm
Posted on: 20 June 2009 by Mat Cork
I've got a switched socket...is it as simple as taking the front off, unwirring and then rewiring and screwing on the new switchless front. Obviously with the mains turned off to save electricity.
yes
Posted on: 20 June 2009 by Trevor
It is worth checking where the individual wires terminate in the new socket as to the existing socket as if they are in different places and the wires are short they may not reach.
Posted on: 21 June 2009 by bob atherton
Good point Trevor. As they are switched MK's at the moment I guess I should use unswitched MK's. Unless the Crabtree ones really are worth getting.
