sound editing saftware
Posted by: Sloop John B on 07 April 2005
Do you know of a sound editing software package that will:
Split sound files
Fade out a sound file
Stitch together sound files
Convert the stitched file into a real audio file for web streaming.
John
Posted on: 07 April 2005 by TomK
I use Sound Forge which does all this and much more. It's not cheap though unless you've got a generous friend with contacts (like I have!).
There's bound to be something available as freeware though. Google "free sound processing software" and you should find something.
Posted on: 07 April 2005 by Rasher
Traktor DJ will do just that.
Look here for a general overview. It is simple to use and can do much more than you need.
Posted on: 07 April 2005 by Not For Me
Wavelab
