3M feet
Posted by: Rockingdoc on 17 August 2001
I've done a search but can't find out which 3M feet are the correct ones to use on a CDS2 or LP12. Anyone know the model no.
Posted on: 17 August 2001 by David Dever
...for the correct 3M part number, though the verdict's still out on whether (under the Naim metal feet) they kill the music or not...
On the LP12, they tighten up the sound, though this can be too much in some instances. Try for yourself, but save your original feet.
Dave Dever, NANA
Posted on: 17 August 2001 by Rockingdoc
Oh no, I'm too fearful to go to the land of Mana.
Posted on: 17 August 2001 by Martin Payne
the part no is SJ-5076. See Bump-on page at 3M..
See Andrew Weekes comments re free samples atthread "Here is what happened when I removed the Trampolinn... Is that what was supposed to happen?"
Cheers, Martin
