£100 DVD player
Posted by: Diccus62 on 26 December 2006
This may well be too cheap for you guys but I need a bog standard player to play mainly the kids dvds through normal telly. Two scarts minimum. Toshiba seems to have a good reputation on this Forum.
Diccus Smile
Posted on: 26 December 2006 by Fozz
Can you go to £120.00? This forum always pushes you eh? Anyhow get the Cambridge Audio DVD 86 from Richer Sounds. I have just set up a mate with a stereo home cinema with this. Amp is a a Nait 3 with original Rega Elas and the sound is frankly amazing for this price. Even on CD.
This player has digital video output as well.
Hope that helps
Posted on: 27 December 2006 by JAB
What HiFi seem to recommend a couple of Toshiba players, one at £50 and another around £100. Frankly, with the kids I'd go for the cheaper one!
Posted on: 27 December 2006 by Diccus62
JAB
Yeah I had a quick look at What Hi Fi today and the Toshiba cheapies look good value, prob just the ticket for the kids. I'll have a neb in Curry's
Fozz,
Sounds like a good set up for your mate but a bit pricey for me. Cheers for the advice.
Diccus Smile
Posted on: 27 December 2006 by Former member
Diccus have a look in tesco or there web they have some bargs ,also if you have a Aldi near you they have a player with 2 year gt £69.00 with hdmi they call them tevion but they are samson and LG .regards munch
Posted on: 28 December 2006 by Fozz
Hi that's fine Diccus, I was really only suggesting the player part LOL, for its brilliant sound quality, you may have found it in your system... Happy New Year.
Posted on: 28 December 2006 by Diccus62
Fozz/Much/JAB
Bought a cheap Toshiba (£35) last night and colour is all washed out. I shouldn't be such a tight Ar**. The bugger's going back.
Grump, grump
Diccus Smile
