Under Suspension - or not?
Posted by: andy c on 08 November 2003
Hi,
I need advice on the following:
My current systems is on a 5 shelf Mana amp stand/sound stage and is (from top to bottom):
Axis/Akito/K9 TT
Naim CDX2
Naim 102 pre
Naim 180 power
Hi-cap/NAPSC
SBL's on sound stage
I am shortly to upgrade to a 282 pre, and a XPS2 for the cd, but then I will be a shelf short. This will mean in the short term putting the Hi-cap on the sound stage underneath the 5th shelf. This will have to be so for around 3-6months.
Do you have any suggestions for isolating the hi-cap e.g. oak cone feet (Only a suggestion)
thanx for any replies (I know about Fraim - i'll be auditioning that as and when...)
Axis/Akito/K9 TT
Naim CDX2
Naim 102 pre
Naim 180 power
Hi-cap/NAPSC
