Paging Vimal
Posted by: Martin Payne on 13 November 2003
Vimal,
your reply e-mail bounced.
Please check your reply address and mail me again.
cheers, Martin
E-mail:- MartinPayne (at) Dial.Pipex.com. Put "Naim" in the title.
Posted on: 15 November 2003 by vimal
Martin
I have sent you pm,hopefully it will work,
if not I will try to get the file by other means.
thanks Vimal
Posted on: 16 November 2003 by Martin Payne
Vimal,
I've tried to re-send again.
Let me know if you receive it. Apologies if you get it twice!
cheers, Martin
Posted on: 20 November 2003 by vimal
Martin
No joy,I have setup the correct return address again,and hopefully it should work.
I will also PM you with two E-mail addresses.
Thanks for persevering.
Vimal
Posted on: 21 November 2003 by Martin Payne
OK, I've re-sent it again. You might even get it once in each of the two accounts.
cheers, Martin
Posted on: 22 November 2003 by vimal
EUREKA
Received the file,many thaks Martin.
Vimal
Posted on: 22 November 2003 by Martin Payne
Glad it finally arrived.
I think there were major problems on some of the mail servers at my end.
cheers, Martin
