naca5 compared to kimber 8tc
Posted by: hifi-dog on 12 February 2004
speaker cable again i know but being new to naim has anybody compared the above? - i am using kinber 8tc at present but if naca5 is better, sale of the kimber will release funds for more stuff;-). Using meridian 506/20, naim 112/150/fc2.
cheers
Posted on: 12 February 2004 by Noel
With an olive NAP250 and SBLs I preferred the Naim to the Kimber cable. Most importantly, what speakers are you using?
Noel
Posted on: 12 February 2004 by hifi-dog
oops, sorry forgot those! - Quad 21L ( floor stander between the 12L monitor and 22L )which is 89 db/6ohm with carbon drive unit/soft dome tweeter.
Posted on: 12 February 2004 by syd
Hi HD
Best thing for you would be to visit your nearest Naim dealer and borrow lengths of NAC A5 pre terminated and compare them to your own. Good Naim dealers usually have a few sets made up that you can borrow. I think I would prefer the NACA5 but you may be feel differently.
Yours in Music
Syd
Posted on: 12 February 2004 by andy c
I use Kimber 4 PR with my 180-sbl's, and it sounds fine. You do need to try within the context of your own system tho-as has been suggested elsewhere. Good suggestion re borrowing some Naim cable...
Posted on: 14 February 2004 by Goldstar
I used Kimber 8TC but I was just starting out on the Naim learning curve. My Naim dealer brought some NAC A5 to try.
The bass was suddenly there and the 250 amp seemed to relax and sing. The 8TC cable tends to drive the amp towards oscillation.
Other Kimber Kable may prove to be less harmful, but my experience and advice is to stick to what Naim recommend as the cable is part of the amp output circuit.
Hope this helps, Robert
Posted on: 14 February 2004 by Nuno Baptista
I agree with Goldstar
The Naca 5 is part of the amp output circuit
I tried Kimber 4 tc and it was a disaster
MY system : Naim Nait 5 amplifier,Naim cd 5 ,Epos M 15 speakers,Naca5,FC2
