Audiotech Wall Shelf
Posted by: Paul Gravett on 07 February 2002
I have noticed that there are 2 Audiotech Wall Shelves for sale on Loot. The ad says they are ideal for LP12s and Naim. Does anyone know what they are like and how much they cost new? Does £50 represent much of a bargain? I am looking for a good support for my LP12 which is currently standing on top of a six shelf Quadraspire unit
Paul
Posted on: 07 February 2002 by Steve G
Paul
I've no experience with the Audiotech but an option to consider is the Wallnut II from British Audio Products which is £65 new. See http://www.britishaudio.co.uk/wallnut2.html
I can't compare this to any other wall shelf but certainly moving my turntable (and CD player - it's got 2 shelves) onto it was a significant improvement compared to having then on my Target rack with the amps.
Steve
Posted on: 07 February 2002 by Bosh
I do they're mine
Paid £150 each for them and used them for 4 years with my Naimed LP12/CDS/52/4 pack/SBL. Changed to Fraim when I moved to a drylined house last autumn and dared not risk them
The shelf sits on 4 height adjustable spikes on a light weight frame. These slot onto 4 expanding wall bolts and are loosely but very safely held by 4 nuts.They're significantly better than the Tripods I had previously used. The Fraim is significantly better still though (so it should be at the price)
Posted on: 07 February 2002 by Mike Sae
I just bought one off E-bay.
I hope to use it for my CDX or Rega3. It was so cheap I think it's worth the experiment. I'll post impressions of it once it's installed.
Posted on: 07 February 2002 by Dr. Exotica
I too need a wall shelf (floating floors problem). I am trying to decide between buying one of the old standards (e.g., SoundOrg or Mana), or picking one up second hand. These things rarely come up on Audiogon... Mike, what search string do you use on Ebay? I have been quite unsuccessful in my attempts.
Erik
I just type "naim". Some people add "naim" to the header of whatever they're selling if they think suckers like us would be interested.
I'll e-mail you regarding a good deal...
Posted on: 08 February 2002 by bigtrak
Hi Bosh
Have you still got the black 4 pin Snaic? If you have could you email me awphoto@blueyonder.co.uk
I live in Sheffield so I should be able to pick it up.
Posted on: 08 February 2002 by David Sutton
Paul,
I used an Audiotech wall shelf for a number of years under my LP 12. It was certainly better than the target shelf before it, but not really worth the cost. I would suggest looking out for 2nd hand Mana stuff. Its loads better.
Good luck
