Idiots Guide to CD Labelling
Posted by: Diode100 on 26 September 2006
I'd be extreamly grateful if anyone coulp point me in the direction of an idiots guide to burning labels onto CD's.
Posted on: 26 September 2006 by Diccus62
..... and while were on the topic, the best way to print track listings for those plastic cd boxes from ichoones.
Sorry to hijack topic Diode
Diccus
Diccus
Posted on: 26 September 2006 by SteveGa
Are you talking about those horrible paper labels that you need to print and then stick on - or are you talking about printing directly onto CD? There are a lot of ink jets now that claim to print directly onto CD's but the real trick is the template (usually supplied) that opens in photoshop / word / or my case In Design. Once you've got that, the printable CD there is usually only the problem of doing it! There are a few CD/DVD printers around today that remove the hassle see here - they are about £99 so if you are doing a lot...quote:Originally posted by Diode100:
Find a young person to do it for youquote:Originally posted by Diccus62:
Diccus
Posted on: 26 September 2006 by Rasher
Avoid the stick-on paper ones. With heat they can start to lift off, and if that's happening while it's playing it can do a lot of damage - especially in an in-car slot feed jobbie.
Posted on: 26 September 2006 by Martin Payne
My Canon Pixma 5200 can do this, and is very good.
It comes with a little application called "CD Label Print".
quote:There are a few CD/DVD printers around today that remove the hassle see here - they are about £99 so if you are doing a lot...
The excellent Canon 5200 can be bought for about £80.
I understand the print quality on some dedicated CD printers is pretty crap, too.
cheers, Martin
Whilst we're on this subject, I want to buy some audio CDs (the proper music ones) with printable surfaces.
Can't find them anywhere.
Can anyone suggest a source in the UK?
cheers, Martin
cheers, Martin
Posted on: 26 September 2006 by Seanf
Printable CDs are fine, they cost a bit more of course and you need a compatible printer. My 3 year old Canon does a good job so I expect more recent and cheaper models to do at least the same.
What about LightScribe discs? LG have a DVD burner that goes for around €50 here. Again, blanks cost more and they only 'scribe' in monochrome but I'm sure that's the way forward.
Sean
Sean
Posted on: 26 September 2006 by BigH47
quote:Whilst we're on this subject, I want to buy some audio CDs (the proper music ones) with printable surfaces.
Try these chaps:-
http://svp.co.uk/index.php
Posted on: 27 September 2006 by Martin Payne
quote:Originally posted by BigH47:quote:Whilst we're on this subject, I want to buy some audio CDs (the proper music ones) with printable surfaces.
Try these chaps:-
BH,
thanks, but no printable audio discs.
cheers, Martin
or http://ukdvdr.co.uk/shop/CD-Media-c-252.html
Steve,
thanks, only one audio disc (the Dysan), but that doesn't have a printable surface.
Again, the audio discs are not printable, although they do have a reasoably-priced audio CD-RW that I have also been looking for.
The discs I want are the special "designed for domestic CD recorders" ones.
Thanks if anyone else has any suggestions.
cheers, Martin
Posted on: 27 September 2006 by SteveGa
Martin I'd talk to these either guys http://www.stanleysonline.co.uk/category-54.htm or aprmedia see what they can suggest.
Steve
Steve
Posted on: 27 September 2006 by garyi
To print a listing in itunes:
Make a playlist.
Select playlist.
Goto file and print.
Jobs done.
As for CD labelling, get a permanent black pen and use movement in your wrist and arm to make writing.
Make a playlist.
Select playlist.
Jobs done.
I think Diccus is worried that everything is slowing down now he has reached Seniority - maybe he needs machines to do some things for him now????
Posted on: 27 September 2006 by andy c
I use an Epson R200 for Cd printing. You can also do sleeves etc with the software provided...
Posted on: 27 September 2006 by Diode100
Thanks to you all for feedback and interesting associated issues. Do I understand correct that there are three options:-
1) A printed stick-on label - uses printer
2) Use a CD with a printable surface already attached - uses dedicated printer.
3)Burn / Etch an image directly onto a (special) disc - but not in colour - uses disc burner.
So, what are lightscribe discs ?
thanks again
thanks again
Posted on: 27 September 2006 by Diccus62
quote:Originally posted by SteveGa:quote:Originally posted by garyi:
I think Diccus is worried that everything is slowing down now he has reached Seniority - maybe he needs machines to do some things for him now????![]()
After watching an episode of Dad's Army the other night where Mainwairing tries on a hairpiece and John le Mesuirer nearly wets himself laughing you might be right.
Did you get my email Steve?
Awd Diccus (hearing and eyesight going horribly pear shaped but at least i'm not losing my hair)
Sheer genius (Dad's Army).
Bl**dy e-mails - didn't see it, you might have been canned!!
Steve
Diccus
Was it headed: "Quassam Rockets"; "loose that exyta falb" ??; "64% of members got laid" (only 64% - not joining that club); "Refill Reminder Chester" (don't mind if I do)
If not then no! Try again - see profile for address. Send message with Diccus in the header.
Steve
Steve
sent again Stevie boy
Are you Christy Moore advertising gigs at The Point for Christmas? If not nothing here yet. Will report back at the Hendrix Appendix thread as and when (or indeed e-mail you!)
Steve
Steve
Posted on: 27 September 2006 by Seanf
Steve,
bingo - Stanleys seem to list what I need.
quote:MITSUI CDR 80 MIN AUDIO WITH WHITE FACE LAB
Many thanks.
cheers, Martin
Posted on: 27 September 2006 by BigH47
Try these chaps:-
BH,
cheers, Martin
Sorry but I faound at least 2 makes from £12/100.
Howard
