Linn Linnk
Posted by: Eric Barry on 16 March 2001
--Eric
Never heard of a Linn Linnk, only a Pink Linnk. The Pink Linnk was a battery-powered power supply for the LP12 made by Pink Triangle. It was meant to be pretty good.
Frank.
John
[This message was edited by John Channing on FRIDAY 16 March 2001 at 16:14.]
"Linn Moving Coil Pre-amp" and was a
little box that housed Naim phono
boards and was built by Naim(check
the Naim history page). It was
connected via a baby "naps" by a hard-wired NAIC. To answer the questions
1)Could it be powered by a snaps or snaps2? 2)Would it be superior to the phono boards in a 32-5? 3)How much inferior to a Stageline would it be? 4)Would it be worth picking up on the cheap?
1)You could use any 4-pin PS to power it.
2)The phono boards in it are NA323/1 (S), so if you use a cartridge that sounds best with "K", or are a newer vintage, probably not.
3)don't know
4)Yes. A friend picked one up for $35. which is about what it's worth second hand. Here's what he did; he replaced the stock Linnk phono boards with NA323/3K from his 32 and it was a minor improvement over just using the 32. You have one main benefit; the Hi-cap isn't powering the phono section in the 32, hence you are "board-pulling" and improving other sources.
Ron The Mon
Does the stageline take a dual-rail or single-rail supply?
--Eric
If you duct-tape your phono boards to the back of your turntable and hard-wire the tone-arm leads and a 4 or 5 pin DIN to it, you'll achieve better results.
An addendum to my above post: the Linnk is mostly only good for looking at and saying "WOW, so that's what people who couldn't afford a Naim pre-amp in 1980 used for an Asak"
Ron The Mon
--Eric
The reason I responded the way I did to your
above post is you wrote the word "SNAPS". If
you were to buy a Linnk second hand for
$25.-$35. and use it or monkey around with it,
it would be a good value. As soon as you start
adding $75. or more for a SNAPS, the VFM
decreases and other avenues become more cost
effective.
And yes, about 12 years ago I put my phono
boards in my LP-12. How do you think Naim got
the idea for the Prefix?
Ron The Mon
--Eric
The Linnk was designed and made by Naim for Linn some 20 years ago. I haven't seen one in quite a while in the States, but before NANA got started in '86, a fair number of Linnk's came across my test bench at Naim, so I'll stoke up the memory cells a bit. The Linnk was quite small, and the circuitry from a pair of 323 "S" boards was re-arranged and squeezed onto a single circuit board along with regulators, power supply capacitor, and rectifier. Yep, it took AC power from a small separate transformer via a coax power plug....no "NAIC" interconnect and no plug in phono boards. It had rca in and out jacks as it was not intended for use with a Naim preamp. In it's day, it did a decent job for those who wanted to put an MC cartridge on their LP12 rig and avoid using a nasty step-up transformer into an MM phono input. However, relative to plug in Naim MC phono boards the Linnk suffered from more crosstalk between channels, more noise, and a very basic power supply. The Stageline and Prefix we have today are in a different league entirely.
Chris West
NANA
--Eric
