Cartridges
Posted by: count.d on 21 December 2001
Will be getting an Armageddon.
If I were to upgrade the cartridge, is there a big difference between Asaka and Arkiv?
Arkiv is about £1,200.
Is it worth upgrading to this or are there better value for money cartridges?
The arkiv is a different beast in all departments, especially the arkiv2 with the boron cantilever. I like it a lot but IMO there are alternatives to audition.
The dynavector range is well worth a listen. The d17mk2 is a real bargain at approx 500 pounds uk. The xx2 at a grand is supposed to be the business although I have yet to hear it.
If you intend to spend this sort of money I would make sure you have the very best arm, power supply, support to make sure you make the most of it. Enjoy
I haven't tried other modern cartridges in the Ekos. In an ARO I've tried many such as Ortofon KontrapunktB (£750), Dynavector 17D2 (£450), XX2 (£1000) and Te Kaitora (my favourite but £1700). However, I can't attest to their effectiveness in the Ekos since I haven't tried them. In an ARO I would take any of the above (even the 17D2) over the Arkiv due to that mismatch.
In the Ekos, the Arkiv works very well (as you'd expect), and I can recommend it as an upgrade from the Asaka.
Frank.
All opinions are my own and do not reflect the opinion of any organisations I work for, except where this is stated explicitly.
My experience with the Arkiv in an ARO was horrendous - it came out bright and nasty.
I think there must be something wrong with the set-up to get these results, I would say the Aro/Arkiv2 is a pretty good match, and certainly isn't bright. The only thing I can suggest is that with the Aro the essential thing to ensure is that that the Arm pillar and three cartridge bolts are not done tight at all.
Happy x-mas
Dev
