52 PS
Posted by: Robert St. on 11 May 2005
I was wondering how the 52 PS compares to the Supercap? I would be using one of the power supplies with a NAC 52 produced somewhere between 1990 and 1995.
Thanks,
Posted on: 11 May 2005 by Tam
Welcome to the forum Robert.
I'm afraid I can't answer your question (though I believe naim certainly used to offer conversion of the 52ps to a supercap, which suggests the latter is better, certainly more versatile).
You will, however, have better luck getting an answer in the hi-fi corner section of the forum (which is devoted to hi-fi), this is the music room, where, well, you can probably guess....
Adam will probably move the thread over there when he spots it, but it might be just as well to start a new one.
regards,
Tam
Posted on: 11 May 2005 by kuma
psst..
Robert,
You're in the wrong room.
Go over to the 'Hifi Corner'.
Posted on: 12 May 2005 by Robert St.
Again. I first posted this question on Martha Stewart's web page. I did get a nice recipe for tarts however.
How about this instead - I want to sell all my Naim gear and make sure you stop by my shop. I will start advertising here daily.
Amazingly enough, a 5 minute search next door in "hi-fi" yieled the results I wanted.
