n-Vi and second room system
Posted by: Jonathan on 21 January 2006
I have CD2, 82, 250 and 2 x hicap and Epos es22s. Plus various dvd players, surround amp etc.
I am planning to purchase an n-Vi to replace the two (poor) dvd player and the yamaha surround sound amp. I am also wanting to set up a new system in another room.
My plan is to replace the CD2 with the n-Vi, buy a second hand NAP5i so I have the n-Vi with 82, hicaps and 250 in one room and the CD2, NAC5i in the other room (with epos es11s). The first setup is for day-to-day use (TV, CD and DVD), the second is for an occasional CD listening room.
I have a couple of questions. Firstly, is there a better solution for a similar outlay? And secondly, what are the limitations of having the NAC82 without unity gain (ie I need to turn to 12oclock to use it).
Jonathan
Posted on: 21 January 2006 by AV@naim
Er...cant think of a reason other than having to change volume at present.
Just going to have a think.....
Why would you not have the unity gain mod? (Other than cost.. Smile)
Posted on: 21 January 2006 by Jonathan
What is the cost for the unity gain mod? I have to ship to and from Greece......
Off the top of my head I cant remember exact figure. Frown
Either I can get back to you Monday or failing that contact info@naim-audio.com, and put a reference to AV@naim in the mail.
Posted on: 22 January 2006 by Manu
Jonathan,
If you are not planning other sources than the N-VI built-in DVD player (or the TV),IMHO you don't need the 82 in this system. I don't think the 82 will improve music over an N-vi/250. I don't think there is a direct analog output from the CD player as in the DVD5.
You should by a NAP instead of a NAIT5i and use it with the 82/hicap and your CD2.
Emmanuel
Euphonie
Posted on: 23 January 2006 by Jonathan
Manu,
Thanks for the suggestion - As I still want to listen to CDs in the main room, the n-Vi as well as CD2, 82, Hicaps and 250 seems the best option.
Then simply go for a CD5 and Nait for the spare room (I used to have a Yamaha CDX2 and quantum amp there - but they both died of old age recently).
Jonathan
Posted on: 23 January 2006 by AV@naim
Sorry Jonathon
have been in hospital all day, will check out the price first thing tommorrow. Red Face
ouch - nothing serious I hope. No worries/rush. Snow here in Greece so I am not going anywhere in a hurry - for the moment.
Posted on: 24 January 2006 by AV@naim
Jonathon,
An 82 costs between £120 - £160 depending on age and condition for the unity gain mod.
Posted on: 24 January 2006 by PatG
Sound about right, I has a quote for £110 for the same mod to a 102. P
102 slightly easier to mod than 82 and 52
