Naim Uniti Ethernet LAN
Posted by: vlada on 07 June 2010
I do not know if this has been asked before. So if yes pls. apologize. What kind of ethernet LAN Naimuniti uses: Gigabit (1 GBit/s) or Fast (100 Mbit/s) ? Thank you!
Posted on: 07 June 2010 by David Dever
Should be 100Mbit - no need for GigE given the bandwidth required for a hi-res stream (4.608Mbit/s).
Posted on: 07 June 2010 by 0rangutan
Vlada, do you want to know what the Uniti supports or what is a suitable speed to connect at?
David is correct in that 100Mbps is quite adequate for streaming.
Whether the LAN port supports GbE is less clear.
No GbE on current units; Wi-Fi is 802.11g....
