Naxo Manual
Posted by: gusi on 08 September 2003
Hi Everyone,
I just received my naxo3-6 but it came without a manual. Does it use the same connections as the snaxo3-6?
Do outputs 5-7 connect to 3 250's?
cheers
Gus
Posted on: 08 September 2003 by Jens
Gus,
Are you back in Perth already?
Jens
Posted on: 08 September 2003 by gusi
Unfortunately only the snaxo and snaxo2 manuals are on the web. Eventhough they are pretty clear, I wish most computer manuals were this complete, they don't explicitly cover the naxo.
Back in Perth next week.
Gus
Posted on: 09 September 2003 by Martin Payne
Gus,
this is the relevant page from the old-style manual (presuming you are using NAP250s).
BTW, the NAXO will always connect to 'socket 4', via a 5-pin cable. The connection of the 4-pin cable varies for HiCaps of different vintages (the diagram is correct for a chrome-bumper unit only). Follow the wiring instructions on the back panel of the HiCap.
cheers, Martin
E-mail:- MartinPayne at Dial.Pipex.com
Posted on: 09 September 2003 by gusi
Thanks Martin,
That is much appreciated. My Hicap is chrome bumpered so it is the right diagram.
thanks again,
Gus
