What we need... a recordable source
Posted by: Andrew Randle on 19 March 2002
Andrew
Andrew Randle
Currently in the "Linn Binn"
1) HDDs are unreliable. I have had two break down on me, effectively losing the data (which I had backed up on CD-ROM anyway
2) You can only store about 50-60 high quality recordings on a 50GB HDD.
3) They're so unromantic. Kind of an anonymous box grinding away in the corner.
I'd prefer removable media that is fairly inert.
Andrew
Andrew Randle
Simon
It should come without any copyprotection and an interface to connect the computer to it: maybe PS2 or USB for an external keyboard and/or a SCSI-port for both connecting more HDDs to the CDR or to read the internal HDD from any computer with SCSI...
This would be a very nice copy-station for me! - Did I forget anything?
Jun
- Jun
Yes I mean a source that is able to record. I do have a PC, although a very long interconnect would be needed for the task. Also a PC is a very noisey environment and not the best device for the job. Sound cards at best seem to be very round earth.
Andrew
Andrew Randle
Paul
If you want to record analogue to digital buy a decent sound card for your PC. How do you think most producers get quality samples fom old recordings?? Put it through a sound mixing/mastering program and viola a new CD of your favourite artists. Doesn't sound quite as good as the original?? That's a matter of opinion. If you think not, then listen to the original source. If you are recording from the radio, it's the same process. Record to the hard disk of your PC (if it crashes, then you should have bought a Mac) and then put it through your sound authoring program. easy really.
Could naim produce a product that does this? probably? Could they make any money from it? Absolutely not. Why not? Cos most of their kit is overpriced anyway.
I think a system with RAID controllers (basically protection against data loss due to hard drive failures) with massive storage capacity (500GB+) is very enticing to me. The ability to directly download high-quality recordings (rather than transcribe from LP or dump from CD) is also interesting. If you've ever tried the TiVo television recorder, applying that concept/logic to radio & music seems exciting too, given the explosion of small and independent music labels.
I was just talking with a friend and fellow vinyl collector/enthusiast, pondering how buying, owning, and playing back recorded music will change over the next 20 yrs, and what it will be like to have large libraries of old-format material. Will they be romanticized like cylinders, or the butt of jokes like the 8-track?
M
However I would prefer a Minidisc, as I use MD in my car. IMO it is suited ideally as the sound quality is less of an issue than in the home, plus compared to CD's (and especially CDR's) you can throw an MD in the glove compartment and not worry about it being scratched.
Plus the benefits of MD with the track moving, deleting etc being very simple makes them also very simple for editing.
Scott
