XBox 360 - Which version ?
Posted by: Calum F on 29 May 2008
I may buy an XBox 360 later in the year. Is the mid-range version with 20GB likely to be OK for
"real world" use or to put it another way is the £ 60 premium for the Elite (120GB) justified or needed ? Thanks.
Posted on: 29 May 2008 by djftw
That would probably depend on whether you're going to use X-Box live to download games, movies etc. If so the extra HD space is worthwhile. If not, then probably not!
