New Naim AV products at Bristol...
Posted by: SC on 28 February 2010
Gotcha..!
So, where are they all..??..To replace all the AV items they have dumped out of the range of late.....?
Frown
Still, good news the HDX has been revised finally Smile - to what it always should have been from launch - although I'm guessing, like others, as to what the exact spec and changes are as it seems the PR department is playing catch-up again....
Steve
Posted on: 28 February 2010 by james n
You mean you didn't see the Scaler card then Steve ?
James
Posted on: 28 February 2010 by SC
Big Grin
I didn't even go (had a feeling it would be a nightmare there) but if there had been word filtering through of the 'shipping soon' scaler card I would have eaten a hat..!..whilst naked...standing on the plinth in Trafalgar Square...upside down.....You get the picture ! Winker
Posted on: 02 March 2010 by Neill Ferguson
Although Naim have confirmed they have been working on products I fear that they will be a while of with the launch of 3d. I had a quick scout around various websites and very few manufacturers have updated there product line. For example Linn, Bryston and Naim are all running with old and dated products.
With the short life span of the Nvi I do wonder if Naim will truly bother with a stand alone Av pre amp more than likely and rightly so it will be a digital bolt on to the core two channel systems. I think now that the likely hood is you would be better buying a Denon box and adding it into your system that way.
