A possibility for a cheaper 82/52 ?
Posted by: Arye_Gur on 21 September 2001
I had this possibility with my QED and never used it.
As Naim are paying a lot of attention to each detail, I guess this extra feature costs quite a lot, so don't you think Naim can come with a 82/52
without this feature - and maybe it will be considerably cheaper ?
Arye
When I purchased a used 82, my dealer said the current 102s were better. But they did allow that the 82 with 2 Hicaps was better than a 102 with one hicap.
Phil
... and after a short but pregnant pause he said, "Oh by the way, Phil - I just *happen* to have a used 102 in the back. It's the version that's much better than the 82. I mean, it's a bargain, really ..."
Thomas
IMO, you're dealer was wrong. I've owned both a 102 and circa '93 82. The 82 was a whole lot better! In fact, I would gladly take a bare, used 82 over a 102/NAPS/Hi-Cap.
-=> Mike Hanson <=-
Hanson, you could have saved me this experience if you had only come down a few hundred bucks on 102 you were selling! Oh - but then the dealer would have told me how much better a new 102 was, when compared toa used one!
Regards.
Phil
I would not consider a high-performance expensive pre-amp without separate record facility.
As the others say - what you're asking for is offered in the 102. Or hell, the 72 for that matter.
Rico - SM/Mullet Audio
cheers, Martin
Meanwhile, I'm really happy with my system now, so I see no need to get it serviced.
Now, if only my favorite FM radio came back (it was sold a few months ago to a conglomerate for $163M and switched from classical to something else).
I guess the 102 is not as good as the 82.
So what is wrong with the idea that there will be a "80" and a "50" pre, without this feature ?
The 82 and the 52 will stay as they are.
Arye
I guess it would be called the 130, being the love-child of 80 and 50 ![]()
Alex
