Considering a DAC...have questions
Posted by: Woods Scot on 13 August 2010
I am consider the addition of a Naim Dac into my existing set-up. I am wondering how I can connect my MacBook Pro. Is it as simple as attaching a USB from one to the other and playing through itunes? Curious
Please be gentle as I am new to this realm.
Thanks in advance
Posted on: 13 August 2010 by ferenc
You need a Toslink cable or a kind of USB to SPDIF converter. Can not connect the MBP's USB to the DAC directly. The USB on the DAC is for USB memory and iPod, not for computer.
Posted on: 13 August 2010 by Woods Scot
what are some recommended usb to spdif converters to be used with the Naim Dac?
Posted on: 13 August 2010 by Guido Fawkes
hiFace is what I'm using
Posted on: 13 August 2010 by Aleg
The HiFace is widely used and recommended and also reasonably priced.
I would suggest you use the find function in this forum and search for HiFace, you will find loads of usefull tips and experiences.
aleg
Posted on: 13 August 2010 by scotman1973
Thanks. I will check it out. If anyone has any other suggestions and/or experiences, please share.
Considering the price, HiFace is a good choice without too much risk. For a bit more budget you have much wider choice, the bigger HiFace EVO is one of them, but there are dozens of others as well.
Posted on: 13 August 2010 by Jack
If you are just starting out on computer ausdio its also worth checking out the Computer Audiophile site.
The M-Audio device also seems to be recommended. You can also use the firewire interface and a range of convertors.
As mentioned the HiFace seems to be very popular
Posted on: 13 August 2010 by pcstockton
Scotman,
There are a number of USB/Firewire converters out there, at wildly varied pricing.
M-Audio Transit ($70)
M2Tech Hiface ($200ish)
M2Tech Hiface EVO (?)
Wavelength Wavelink ($900)
Weiss INT202 (Firewire) ($1300ish)
Just to mention a few.
There are also a great many PCI sound cards that can cut out the USB converter middle man (not unlike you using your stock output mini-Toslink you might have on your Mac)
Just to get the ball rolling, you might want to simply try the stock digital output of your Macbook. You will only need a Mini-to-Standard Toslink cable. Or a standard toslink cable with an adapter for the mini jack on the Mac.
And when you say "considering a DAC", you obviously mean "getting the Naim DAC", right?
-Patrick
Posted on: 13 August 2010 by js
Originally posted by pcstockton:
Weiss INT202 (Firewire) ($2000ish)
-Patrick
Fixed.
Eek
$2000???????????????? Whoa. For a converter? Somewhere in the world Andy just puked in his mouth.
Thanks for the correction JS.
It is really good when you add a napsc. Make that $2500 Big Grin
JS,
How exactly do you modify the NAPSC to use it with anything other than the appropriate NAC?
Do you think you could modify the NAPSC to be used on the Mtech EVO?
How much would that modification cost approximately?
Thanks,
Patrick
Sure. No warranty and not too much more than stock. Naim has never authorized this sort of thing. I think we should stop there as this isn't a sales forum. I think ferenc may try one for the evo.
gotcha. thx
Sure, no time yet unfortunately. Plus I am thinking to try a Supercap with a Sonic 305 (or MH ULN8, it is almost the same)... Cool
Posted on: 13 August 2010 by naimUnT
I am also new to computer audio so be kind! But, there are some DACs (like the Tranquility USB DAC) which allow direct connection from computer to DAC via USB cable, without the need for a Hiface connection between. If correct, this provides a much neater solution.
Yes, but with what kind of performance? Demo the DACs, pick the one you like most (and can afford).
Dont sweat the connection details.
While it would be nice if the Naim DAC had this option, its stellar performance makes it a moot point in my book.
I have heard a few USB DACs and none even come close to the enjoyment the Naim DAC brings for me (although a few were quite nice). Scott Nixon NOS, Benchmark, DACMagic, Empirical Audio, Wavelength Brick etc....
The All Naim system is something VERY special.
Posted on: 14 August 2010 by likesmusic
Arcam have a DAC which is hitting the shops for about £300 which has an asynchronous USB interface built in, and wireless promised - might be a more than acceptable solution for the money and let you get into the game.
Posted on: 14 August 2010 by naimUnT
As a matter of interest, have you heard of dB Labs USB Tranquility DAC? Seems it is very analog sounding and brings music very close to vinyl.
Posted on: 14 August 2010 by rich46
[QUOTE]Originally posted by likesmusic:
Arcam have a DAC which is hitting the shops for about £300 which has an asynchronous USB interface built in, and wireless promised - might be a more than acceptable solution for the money and let you get into the game.[/QUOTe
musicical fidelity has produced a stunner. dac at £400 and sounds great
Posted on: 14 August 2010 by pcstockton
I have not.
