How to hang a Wall Carpet
Posted by: BigH47 on 04 April 2006
Can anyone give me any information as to how to hang a small approx (75X50 cm)? Invisible fixing would be prefered.
Howard
Howard
Posted on: 04 April 2006 by count.d
Has this carpet had a fair trial?
I really think you should let us know the defendant's case, before we give our verdict on the best way to hang it.
Posted on: 04 April 2006 by BigH47
Ha bloody ha!
Posted on: 04 April 2006 by erik scothron
Na, beat it then hang it
Come on BigH47, has this carpet been stitched up?
Posted on: 04 April 2006 by u5227470736789439
I think I would rather be hung than walked over for a lifetime! Fredrik
PS: Is the price of being walked over for a lifetime, then to be buried alive, or burned unceremoniously, I wonder?
Posted on: 05 April 2006 by garyi
In Wilton Carpet Factory when they are showing off wall hangings they simply attach a piece of carpet gripper rod to the wall with the spikes pointing upwards.
Job done the stuff sits there permanently.
Posted on: 05 April 2006 by Jagdeep
I hang mine by fastening the carpet using thumbtacks to a long wooden pole along the top edge of the carpet and then simply using some form of string or wire to hang it up like a picture.
You will need to also attach the bottom edge similary to another wooden pole/beam to pull the carpet down (as a weight) to keep it nice and straight.
Jag
Jag
