O. Peterson, Night Train - what’s with the sound?
Posted by: Thomas K on 06 March 2001
Yesterday I bought “Night Train”, the Verve Master Edition (CD). While the music swings, I find especially the higher frequencies sound horribly phasey – after obliging the balance control I found that on most tracks the high frequencies of the ride cymbal or the hi-hat seem to be panned hard left while the body (lower frequencies) of the same instrument are panned hard right. Has anyone (Ken C, Jonathon Ribee?) ever noticed this?
Of course you sometimes get recordings where one channel will sound brighter – on “We Get Requests”, for example, the bass is hard left and the drums are hard right, so the right channel sounds brighter with the hi-hat and cymbals, but why would anyone split a single instrument like that (and wouldn’t they actually have to use a crossover to do it)?
Thomas
I had not noticed this on my version - a recent Verve remaster, and probably the same.
Also - I managed to get the first track played at the active 3x500 DBL demo at the Bristol show and it sounded OK to me. But this could just mean you are a more discerning listener than myself. This also means there is a room full of people who may/may not have noticed this? HELLO FOLKS - ANY COMMENT?
I should have Martin M and Fox round tonight for a bit of listening. I'll see if I can get a group report on the sound sometime tomorrow - I'll try before we get to far into the wine and beer - hopefully when we have something valuable to say.
Probably immediately after subjecting everyone to Sirota/Tubby. Martin was at the demo as well - and had recently borrowed the CD to play on his 135/SBL based system. Maybe he heard this on his?
Any particular tracks you would want us to listen to? Also if you chuck me the Verve ID No. for the CD I'll check to see if it is the same as mine.
Interesting.
Jonathan
I noticed as well something is "wrong" with the sound quality of Night Train, but I couldn't name it. In general the Verve Master Edition series sound great, Night Train is unfortunately one of the exceptions. I'll have a listen tonight to see if I can hear the things you described.
Ciao!
Willem
The ID I found on the spine of the disc jacket is 521 440-2 (copyright 1997 PolyGram). Try for instance track 2, “C-Jam Blues”: 40 seconds into the track Thipgen starts on the ride cymbal, if you pan the balance control hard left, the ride is all tizzle tizzle, if you pan hard right you get about the same volume for the ride, but all dingle dingle (I know, very scientific). In analogy to the “floating head” metaphor, it’s like hearing the cymbal’s head on one channel and the body on the other (and to my ears it’s not just room reflections causing this effect).
Perhaps someone has a non-remastered version to compare. I’m always a bit wary of remasters – some are very good, but others you simply wonder what the benefits are supposed to be (apart from new revenue for the record company). Anyway, thanks for participating in the “Anorak of the Week” endeavour – wish I could join you lot for a drink tonight!
Thomas
Thomas / Willem - will let you know what the panel think. I don't actually own a balance control - but will try a few things.
Thomas - I'm sure we can arrange a beer at some point in the rest of our lives. I'll look forward to it.
Jonathan
I've got this on original vinyl & on CD ( not remastered I think ) . When I get home & have calmed down a bit, (hard day behind my camera), I will do an A/B & report.
Bob.
My vinyl copy I bought new in 1973 & is a first pressing, the CD is a few years old & is cat number 821724-2.
The ride cymbal is actually a ride/sizzle. The sizzle being paper clip thingys that rattle in regularly spaced holes around the cymbal edge. To me it sounds as if Ed Thigpen has about half the holes filled with 'rivets'.
This track has always had a slightly swirling cymbal top end that is fairly consistent with a sizzle from this period. I'm getting about 80% from the R/H speaker and 20% from the left. The L/H is purely high frequency fizz that is subjectively slightly out of phase with the rest.
I have found that remasters can exaggerate this kind of thing, but as I haven't got one I can't comment in this case.
FWIW, & I know that I'm stirring up a can of worms here but when I used Mana the swirling phasey effect was exaggerated. On Hutter the effect is reduced. These were in comparison to Tripod stands.
If you want to hear a sizzle with lots of rivets try Miles Davis, Kind Of Blue, about 2 minutes into So What......nice!
Bob.
Well, I just listened to Night Train and to my ears the record sounds dull. If you turn up the volume it's less obvious, but the music remains muffled. There is clearly something wrong with the higher frequencies. Could be the thing you found.
My dealer has a version of "We get requests" on cd which sounds much better than the Verve Master Edition version, which to my ears already sounds great. He uses it on demoes from time to time. I have the impression, not so much for the music as to make the rest of us who have the Verve Master Edition jealous! ![]()
I'm looking forward to hear the verdict of the panel!
Ciao!
Willem
You bought “Night Train” as a teenager? Kudos galore! (At 16, I just about managed to ditch Loverboy as my “favourite band” and put AC/DC at the top of my playlist.)
Anyway, thanks for your observations. I suppose the “swirling cymbal top end” you refer to presents quite a challenge for timing accuracy between the two channels – maybe at some point, when the material was recorded, remixed or remastered, the equipment used was simply not up to par and permanently screwed things up for posterity.
BTW, when I switch to mono, the top end and lower frequencies of the ride/sizzle are once again joined in physical unity, but the phasiness is still there.
Willem,
Yes, “dull-sounding” was my initial impression when I first played the CD. As concerns “We Get Requests”, I refrained from buying the Verve Master Edition since I copied a friend’s older CD (not remastered, probably what your dealer has too) – while obviously an older recording, there is nothing about it I would wish to change. I’ve listened to the remastered version and apart from a bit more top end (and hiss), I couldn’t make out any gains in the music. Oh what joy it would be to track down an older CD version …
Now let’s see what The Panel says.
Thomas
[This message was edited by Thomas Kunzler on WEDNESDAY 07 March 2001 at 12:40.]
This was true on both SBLs and DBLs. However, to be honest I don't give two-hoots about any of this after about 10 seconds as the album SWINGS - life's too short!
Sad to admit - but the panel was not quorate as Martin was unfortunately unwell. Also, as Fox was a bit late I did the test all by myself. Sorry.
I have only heard Night Train on this CD (same as yours Thomas) and love it - but have no idea that it can sound better. I agree that it does sound worse than the other Verve remasters I have. I will now look for an older CD version.
The test - I have no balance control and have round earth amps and 'speakers - see profile. If I powered down the right then left power amps - I can definitely hear what you described - but when I play it will all amps on I find it is put togther - sounds like ED T is to the right with the ride on his far left - actually HIS right - but you know what I mean.
Maybe my hearing is going? I'll get Martin to have a listen when he's better - actually he was going to buy this as well, so maybe he can try it at home now?
**** Ah - I see he has ****
Maybe this remaster was designed for weirdo's like me who have girlie round earth stuff?
Jonathan
Thanks Thomas. My first record that I bought was You Really Got Me by The Kinks in 1964, at the age of 7.
Bob ( with a rather smug grin!!!)
Bob - sorry - bob - if I wasn't sure already I'd now know you are a cool dude.
Jonathan
Jonathan, maybe there was just a teency weency bit of sarcasm in that statement?" ;-)))
Bob. (not very cool, but enjoys his music)
do you have a distict taste for the musical stylings of 'Yes'?
Where did all go wrong? ![]()
Martin,
Well, erm... yes I do! I think it transports me back to my misspent, at times combustible (if you know what I mean) youth. Not a care in the world, ahhhh...
I don't think that YES were ever the greatest band in the world, but it just hits the spot for this ageing hippy!
Much love & peace,
Bob. ![]()
I'd wish the same on Jon Anderson however I've yet to forgive his 'Jon & Venagelis' era.
Actually I spotted the track 'Roundabout' on a CD last night. I gave it go. I failed. Good bass playing though. Next stop was Bernard Purdie's verson of Shaft.
Of course, you’re right – perhaps I’m a little too (insert flower and butterfly icons) sensitive (or, if you prefer, anal). In any case I’d prefer the recording to have heaps of hiss, an extreme lack of top end or whatever, I just find it very distracting that the cymbals on an Oscar album should sound like something from outer space.
Thanks for all your replies. If anyone ever gets to compare the remaster with an older CD version, please let me know whether the latter is worth tracking down.
First album I ever bought: Jackson Browne, “Running on Empty”.
Thomas
I bought as well Billy Holiday's Lady in Satin and Louis Armstrong's The Complete Hot Five and Hot Seven Recordings. The packaging of the latter is really fantastic. It's in fact an 80 pages luxurious booklet (great photo's) with four CDs. The sound of the CDs is "historic". I hope to have some time to listen this weekend!
Ciao!
Willem
P.S. My first album was Kiss Alive II! ![]()
FWIW I also have the German Verve press of "Very Tall", which is quite a bit duller, and I have the CD of "We Get Requests" - remaster, which sounds really very good, esp. on a pair of original Quads (ESLs and QII amps).
