linn kabers
Posted by: scottyhammer on 02 February 2004
hello all,
just wondered if any of you are or were running naim amps with linn kabers.?? i used to run kielidhs with cdi-82-180-hicap and was pleased with the sound. how do kabers compare.???
now running cdx-82-180-hicap-pmcob1s. now im very pleased.!!
regards, scotty
Posted on: 02 February 2004 by Tarquin Maynard - Portly
Forget the cosmetic similarities; the Kabers are a much more capable speaker, having a better crossover, better bracing for a heavier cabinet and each drive unit is seperated from the others - when you press in a driver on the Keilidhs, the other one moves out - ie there will be interferance when playing music.
I am on my second pair, and they represent, in my opinion, one of the great speaker bargains; a decent set can be had for under £600. The later sets had a mesh covered tweeter, the final series had bars covering the same. The Ku-Stone ( polymer ) stands are essential to get the most from the speaker. They actually do bass.
Hope this helps
Mike
On the Yellow Brick Road and Happy
Posted on: 02 February 2004 by Julian H
Scotty
I run my Kabers with an olive 250.
The Kabers are an extremely capable loudspeaker which have been very revealing of every upstream upgrade I have done since I have had them.
When I bought them, I demo'd against the Keilidh (amongst others) and found the Kabers to be a significantly superior product.
Mine have the stone bases and they are in turn sitting on M*** Soundbases to great effect.
Kabers can be an aquired taste so I suggest that an audition is a must!
Julian
Posted on: 02 February 2004 by scottyhammer
julian,
so what would be the best ones to go for.??
would a 180/82 combo be enough.??
single or bi-wire.??
regards, dave
Posted on: 02 February 2004 by Jellyheadjeff
Scotty,
I've just bought a pair of Kabers (final spec inc Kustone bases) just over a week ago which I'm running at the end of a CDS3/52/250.
It's bit too early to tell as I'm trying to get used to them still. They replaced large standmounters so I'm missing the bass weight I used to have. That said the level of information retrieval/control is much superior compared with the ones I replaced.
They do throw the vocal balance forward so it would appeal to those that like a fairly bright balance.
Jeff
Scotty
I have only ever used the olive 250 to power my Kabers so I can't comment on the suitability of a 180. My 250 does run very hot on a session though!
Mine are the last spec. ones with the bar fronted tweeters. I think the later tweeters are a little less bright than earlier versions.
I tri-wire Red Face them to great effect (IMO) with NACA5
Julian
thanks again j. much appreciated
regards, scotty
Posted on: 02 February 2004 by Stevo
Running late Kabers with a NAP250 and they're great. Even better on Mana.
The later ones with fully veneered fronts look particularly fine too.....
hi stevo,
you wouldnt happen to have a photo of these late ones . would you.!! ??
scotty
Posted on: 03 February 2004 by Tarquin Maynard - Portly
Jeff
Jeff
I have found the bass response on Kabers can be improved substantially by moving closer to / from a wall. The more solid the wall the better they sound, IMO. Try re-positioniong yours.
Miike
Posted on: 03 February 2004 by scottyhammer
well thanks again boys especially stevo for the picture. they sure do look grand in that finish, is it oak ??
Posted on: 03 February 2004 by Stevo
Scotty,
It's probably American Cherry, which is the finish I have, although in reality it's a bit more orange/less blonde than that pic. IIRC the standard finishes were Black, Walnut, Am Cherry & Rosewood.
That pic also shows the Kustone stands.
Stephen
Posted on: 03 February 2004 by Julian H
and in Rosenut with stones plinths and Mana Soundbases
Posted on: 03 February 2004 by blythe
Yikes - so that's what soundbases look like!
Computers are supposed to work on 1's and 0's - in other words "Yes" or "No" - why does mine frequently say "Maybe"?......
Yes! And that's the only reason I don't have them. But a very kind chap once brought a pair round for me to try, and they sounded quite superb.......
Stephen
Posted on: 05 February 2004 by HardBop
Scotty,
I have run Kabers for nine years (actually choosing them over SBls in my original demo) and feel they are a superb speaker, using LP12 and Karik, but always with Naim Amps (simply the best IMHO). First used 72/140 then 102/180, moving through HiCap and second 180, to currently run them with 82/Supercap/2x180. In terms of any future upgrade the kabers would certainly be my last component to consider changing.
Paul
Posted on: 06 February 2004 by Jellyheadjeff
Quote:
Jeff
Miike
Mike,
They are against a wall (although toed inwards a bit). I think it's a physics thing - they replaced MUCH larger speaks having bigger enclosure & drivers so I'm possibly being somewhat unfair on them.
I am interested though in any experiences of the soundbases - do they help the bass extension? Any bad points? How much do they cost?
Jeff
Posted on: 06 February 2004 by Julian H
Jeff
The soundbases help with bass AND treble extension. They also remove a lot of the Kabers "warmth" giving better PRAT
You really need to try them to see if you like the effect. Don't forget the Mana moneyback guarantee
Julian
Posted on: 07 February 2004 by Tarquin Maynard - Portly
Jeff
Try moving them away from the wall, per my original comments. This may work.
Mike
Posted on: 07 February 2004 by Tuan
Very nice.
Posted on: 07 February 2004 by seagull
Having heard both Julian's and Mike's sistems I can confirm that they are very fine speakers. They sounded very good with the high spec front ends they both have and of course Naim amps.
They do do bass and benefit from giving the volume plenty of welly so maybe a 180 is not quite enough (I'm a 140 owner so what do I know Wink).
p.s. Julian, the Ittok has settled in nicely and I am playing more vinyl now than any at time since I bought my LP12.
Posted on: 12 February 2004 by Stevo
Tweeters
Has anybody tries updating the tweeters in their Kabers?
I've got the ceramic ones with the mesh cover. IIRC my options are the final Kaber tweeters - ceramic with three bars at £140/pair - or the Ninka's tweeters - Neodyniums at £70/pair.
Now Linn Loudspeaker dept's advice was that the Kaber is really a very old and out of date loudspeaker and that technology has moved on so far that I should buy a pair of Ninkas. Somehow I've got a feeling that this is a little biased towards new sales.
I'm running mine passive, and am always likely to be, if that makes a difference (I believe it might with the Neo tweets). I know a lot has been written on this and the other forum about these tweeters, but little of that was about Kabers.
Anyone tried?
Stephen.
Posted on: 12 February 2004 by Mr_Sukebe
I have neodymiums in my own kabers.
The differences are:
- Not very pleasant whilst running in (but that's nothing new to a Naim user
- Slightly brighter do to a different impedence to the old tweeters
- Far smoother and less harsh than the ceramics
- More detail
Overall, I'm more than happy with the changes.
Posted on: 16 February 2004 by Stevo
Anyone tried the three-bar ceramics in place of the mesh-covered ceramics?
Stephen
