HDCD questions
Posted by: Alex S. on 03 May 2001
Do/should HDCDs sound any better than normal ones on my CDX?
Are HDCDs clearly labelled as such?
Where can I buy them (in London or mail order)?
Alex
Posted on: 03 May 2001 by Chris L
I've never heard a comparison between CD and HDCD, but I can tell you that
http://www.vivante.co.uk/
have a list of HDCD disks (as well as SACD, DVD-A, vinyl etc). They do have an online ordering system, but I didn't have much luck with it, and ended phoning.....
Hope this helps,
Chris L
Posted on: 03 May 2001 by Alex S.
I'll try my luck
