Matching an appropriate Cd player with 72/140
Posted by: Kevin Loo on 05 March 2003
I am currently using 72/140. Have been trying high and low to look for a CD3.5 but still cannot find. How about matching it with CD1? Any comments? Thanks
Posted on: 05 March 2003 by Peter C
Any Naim CD from CDI, CD2, CDX upwards.
The 3.5 is a good match but the 72/140 is good enough the handle better CD's in the range.
Lower down the scale try Arcam players.
Posted on: 06 March 2003 by Mat Bon 0013
Kevin,
What CD player are you trying to upgrade from?
The 72/140 would also benefit alot with an addition of a HiCap. For around £700-750 s/h the CDI is excellent value IMO. Make sure they are in top condition though!
Good Luck
Mat
Posted on: 06 March 2003 by Kevin Loo
Well, I am using a Sony DVD player at the moment. Wanting to have a pure CD player. Cannot get any CD players in Malaysia so I have to ask my friend to get one for me from UK. I hope I can get hold of one soon...btw, CDI is about 9 years old isn't it? How come it is more costly than a 3.5?
Posted on: 06 March 2003 by Simon B
Kevin,
The CDi (i for intergrated) was a one box version of the original CDS. It has the same chip set and Transport but the suspension is simpler. Also the power supply is not in a different box and is more in Hi-cap legue than a CDPS.
This makes it a mid market machine i.e in the same slot as a CDX hence the price. Not to mention that its considered better than a 3.5 + Hi-Cap.
Simon
Thanks Simon...but how much should I pay for a s/h CDi? How can I get hold of one? Desperate...
Posted on: 06 March 2003 by Alco
Hi Kevin,
There's a Naim CDI for sale at Moorgates in the UK for 700,- UKP. Perhaps it's possible to ship it to you.
s/h at Moorgate
regards,
Alco
Posted on: 07 March 2003 by Kevin Loo
Hi Saiful,
Where is the S'pore second hand market by the way? Is there an address or website?
Posted on: 07 March 2003 by Mat Bon 0013
Kevin,
Do you have email address?
Mat
Posted on: 07 March 2003 by Simon B
Kevin,
Sorry I didn't get back to you earlier; not been around. UK prices for the CDI are :-
Good condition - some Wear to Transport £600 - £650
V Good + all paperwork box etc - no scuffs on Transport (Nextel ring) £700+
Mint & Serviced £800 - £900.
I picked mine up from a dealer for under £600, it has some wear to the Nextel but works fine. I think I got a good deal as the misreads stopped after I got a new puck and got it levelled.
Personally I would not buy a CDI unless it was guaranteed or I could see it working and judge the level of wear on the Nextel ring. This is a coating on the hub where the CD is placed and held by the puck.
Whilst you are ordering get the dealer to get a new puck for you this will reduce the wear on the Nextel. If the Nextel wears off then it’s a trip back to Naim and a £500 bill.
I would also recommend getting a (or more ) dedicated spur(s) for your system – the CD players really benefit from the better supply.
Simon
Posted on: 07 March 2003 by Rockingdoc
I'd buy a CD5
malcolm
Hi guys,
Thank you so much. I am not that techie and being so far away from UK, I am not sure if I can get a good CDI. But anyway, thank you so much for all the advices. Really appreciate it a lot. My email is kevric7@yahoo.com
Cheers!
Posted on: 16 March 2003 by Kevin Loo
Hi guys,
I finally got a Cd3.5, S/N is 13XXX. Cool player. Now, I have to look for a suitable frame and soon a SBL...Smile
