The n-Vi returns
Posted by: james n on 25 April 2010
No not to Naims product range but back to my lounge after a 6 week absence. New display and latest firmware (and a couple of other bits according to the job sheet). Apart from a working display, DVD access is much quicker (as is general navigation) and whereas it would take about 10 seconds for my plasma to lock to its signal this is now instantaneous. Back to movie watching again Cool
James
Posted on: 25 April 2010 by garyi
I haven't used a DVD player for going on 2 years now, the whole thing seems antiquated Winker
Posted on: 25 April 2010 by C P
Hi James. My N-Vi isn't playing up beyond the usual foible of taking ages to decide if it has a DC or DVD in the tray - but do you reckon it's worth sending it off and getting the latest firmware installed on it anyway?
By DC of course I mean CD.
Posted on: 26 April 2010 by james n
C.P - Might be worth a trip to the dealer to get it checked out. It's certainly a lot better since its repair and update.
James
Posted on: 26 April 2010 by C P
Thanks James. I will.
Posted on: 28 April 2010 by AV@naim
I would always suggest running with the latest firmware if you are seeing issues
See here for latest and greatest:
http://forums.naim-audio.com/e...2929996/m/4372966617
Av
