Linn manuals
Posted by: monkfish on 23 January 2002
Jim
I sent you an email - thanks for the offer!
Guido
Erik
Tried to d/l from the Linn site, but it's stuffed.
cheers, Martin
Try opening it rather than saving it, and then save from the embedded Acrobat (I think you need to use the toolbar button) I don't know how or why the site is buggered, perhaps someone should tell them?
Paul
Paul,
I just clicked on the link for 'Isobarik' from the manuals page. It complained that I had no access because I'd come from some foreign site, when I was on the Linn one all the time.
I then tried 'contact us', typed up an error report (I am a programmer, after all), and got another, much more impressive error instead.
I'm running IE5.5, BTW.
cheers, Martin
I guess it just doesn't like you. Or it's a hitherto unknown interaction between all that aluminium in a Naim 6 pack and the Linn site.
Let me see,
I pressed the 'email Linn' button at the bottom of the page and sent them an email. We will see what happens.
I'm a programmer too, although I find the loose typing and general vagueness of much Web programming rather old fashioned. I think Linn must have a bug in their handling of the 'Referer' header field. I have an HTTP Get program, I'll have a play.
Paul
Martin,
You got an error saying you were from a foreign site from Linn! They are in Scotland and you are in England. Understandable from their point of view. Maybe Alex Salmond has helped develop the web site! ![]()
Milan
