Prefix - mounting for non LP12 TTs
Posted by: John on 24 January 2002
Any suggestions are appreciated. Can someone at Naim comment!
John
I don't want to rain on the parade, but isn't the point of the prefix that it keeps the signal path and number of connectors from the cartridge to the first stage of amplification to a minimum???
Surely, if you can't achieve that then you might as well spend the money elsewhere as the prefix is the same circuit as that on the 5*** cards.(I'm led to believe..)so why bother?
I'm interested because perhaps I've got it wrong. I wanted to make a DIY prefix for my LP12 from a couple of Naim phono cards. I couldn't see the point because my dealer couldn't get me the Ekos arm connector on its own and wanted £80+ for another complete arm lead!! That wasn't within the DIY budget! I still used the cards to build a separate phono and psu stage which I'm very pleased with.
Question, is the Ekos arm connector a pattern part used on any other arms? Does anybody know of a source for the connector.
Best of luck with your plans.
pm ![]()
Jason doesn't seem to understand me. I want to cut leads that connect to the leads that typically go out to the preamp. This is were I intend on fixing the ARO connector so the signal path is reduced significantly. I am using the ARO connector because the prefix is a used one that comes with the ARO connector. My other option would be to cut and soder the prefix leads to the arm leads. I don't like this option because it makes it more difficult to change the prefix in the future. It also voids the warranty on the prefix. I am looking for ideas on storage of the prefix with the P9.
You comment that the internal boards are similar. I have a ground loop problem with the internal boards that is only solved my disconnecting my CDS1 from my 52 and plugging my CDPS into another socket. The internal boards knock down the performance of the 52 when another source is used. I expect to resolve this with the prefix. Try running your TT without any other source, if you notice a performance jump (considerable in my case) you probably have the same problem. Is this a design flaw with the Naim preamps??? I also expect a jump in performance as I assume it is being powered more efficiently and the length of cable will be shortened significantly. If the ARO connector is good for the ARO arm then it should be good for the RB900.
John
[This message was edited by John on FRIDAY 25 January 2002 at 19:24.]
I wouldn't worry about voiding a warranty on the Prefix, since it appears you purchased it used. Generally the warranty only applies to the original purchaser.
Bob
Or, you could have the tonearm re-wired in a continuous run from cartridge tags to DIN, have Prefix modified to DIN-type or use a tonearm cable of your own choosing.
Sadly, the wiring is the weakest link in the Rega tonearm saga.
I am planning on doing the OriginLive internal rewiring at the same time. I have ordered a wire run with bare ends that extends about 3cm from the base of the TT. The prefix comes with the ARO connector so I had the dealer get the corresponding ARO connector from NANA to attach to the leads. You suggested the DIN connector, would this be preferable? if so why? After examining the ARO connector that needs to go on the leads I am very confident the attachement to the ARO connectors will be simple.
What about storing the prefix? Can it just sit on the shelf or should I isolate it be suspending it from the TT base?
Any help is appreciated.
John
'Cos it's not an ARO (!)--use something more standard, leaves you room for trying different arm cables or jettisoning the arm entirely.
If you do this mod intelligently, you'll end up with quite a good arrangement--I've seen too few people who knew how to solder the wire to the ARO plug, with disasterous results. The principal difference between the two is the size (two-point "pincer" contact for both, assuming you've got a good-quality DIN), which is necessary for the ARO to move unimpeded in normal operation.
Dave Dever, NANA
Any chance you could make a sketch and scan it in for us please?
Any hints on the soldering operation also gratefully received......
pm ![]()
[This message was edited by pm on SATURDAY 26 January 2002 at 11:56.]
I am planning to use velcro to mount the prefix on the bottom of the TT. Do you have any other ideas for mounting? Would it be better to have just sit on the self?
Thanks again for your input.
John
Can you explain to me the different setup options for the prefix. I don't fully understand your message but it suggests I have more than one option. I assumed that I would just plug the DIN connector into socket 2 in my 52. You seem to imply a better option.
What about the ground connector. Where do I connect this?
John
Best of luck
I purchased an E prefix to go with my Benz M2 cartridge. I am trying to create a setup that I can easily remove the prefix to send it for modification to a different type when I change the cartridge. Thanks for the info regarding the ground lead. I will have to play around with it to get the best results.
You mention that I should use the straight through boards. My 52 came with boards that I replaced when I bought my E internal boards. Are these straight through boards??? Maybe Dave Dever can quickly comment?
John
