budget equipment supports advice
Posted by: the other nickc on 02 December 2002
I can't afford a Fraim. Can anyone recommend a decent, cheap, equipment support? budget less than 200 GBP ? (If such a thing exists.)
Posted on: 02 December 2002 by NB
Have you tried the Appollo range of stands, they offer good performance at a reasonable rate.
NB
NB
Posted on: 02 December 2002 by David Stewart
If you fancy something a little less 'industrial', it might be worth checking out the Stands Unique range, which are solid and do the job well.
Stands Unique
"Opinions are like belly-buttons, everybody's got one"
Stands Unique
Posted on: 02 December 2002 by Steve G
I beg to differ. I have a Stands Unique stand and while it looks very pretty it was no match sonically for my old Target one, never mind Mana etc.
Steve
Posted on: 02 December 2002 by onlythat
Inexpensive. Attractive and very well made. Like my first girlfriend.
God I miss her.
God I miss her.
Posted on: 02 December 2002 by Alco
I would also vote for the Quadraspire Q4.
It looks good, comes in 6 realwood feneers and sounds good. (neutral)
and.... (compared to a Fraim) it's affordable!
Greetings,
Alco
Greetings,
Alco
Posted on: 02 December 2002 by raymond
quote:Hello Nic, how about something like this? It would cost about £40 and it enables one to adjust the height for all sizes of equipment. It can also be spiked. The 20mm screwed rod cost £2.00 a metre or £6.85 for 3 metres, it was purchased from my local steel stockholders, and the nuts cost 14pence each plus 2 pence each for the washers. The MDF was sourced from B&Q. I drilled and tapped the screwed rod and fitted 6mm spikes.
Ray.
[This message was edited by raymond on MONDAY 02 December 2002 at 18:45.]
[This message was edited by raymond on TUESDAY 03 December 2002 at 12:02.]
[This message was edited by raymond on TUESDAY 03 December 2002 at 12:05.]
Posted on: 02 December 2002 by colin thomas
Which sites have the Quadraspires on offer?
Posted on: 03 December 2002 by Alco
Posted on: 03 December 2002 by the other nickc
looks promising, thanks!
Posted on: 03 December 2002 by --duncan--
Ray.
Looks like one of these:
http://www.tnt-audio.com/clinica/flexye.html
How does it sound?
duncan
Posted on: 03 December 2002 by raymond
quote:Hello Duncan, I sold my Sound Organisation Z560 and built one of these...I personally think that the home built one is a lot better than the S.O, but that's just my opinion. I use 4 rods instead of 3, and I do not fit the rubber washers. MDF dosen't seem to attract the dust like the 560. Sound wise I haven't noticed any difference to speak of....I can't afford Mana as I'm poor.
Ray.
How does it sound?
duncan
Ray.
