which desktop speakers
Posted by: scottyhammer on 24 September 2009
Hi All,
Am about to buy an imac to replace my old pc and wondered if you guys have any recommendations for decent sounding desktop speakers and sub. ?
dont want to go overboard but the prices for these speaker packages in the apple store seem rather OTT.
Thanks, Scotty
Posted on: 24 September 2009 by pcstockton
powered (active) studio monitors? or you can get something by Bose or any number of crap speaker makers.
Recommendation, get an old Nait and a proper pair of budget friendly standmounts.
Posted on: 24 September 2009 by BigH47
Too far away to feed into the main system then?
If yes, then as pcs says.
Posted on: 24 September 2009 by gmischol
I'm very happy with my Eclipse TD 307 PA II
Satellites
There's also a sub to combine with
Eclipse TT 316 SW
Subwoofer
not cheap but very good sound
Posted on: 24 September 2009 by CharlieP
I bought a pair of Audio Engine 2 powered speakers for my daughter, and they are pretty good. hve not tried to match a subwoofer to them. Not in same class as Naim...
Posted on: 24 September 2009 by JBGood
2nd vote for Audio Engine 2's. I have enjoyed using them in a bunch of settings including desktop, TV, and digital piano.
If you do a bit of research, you will see that they generally receive unusually positive reviews. AE 2's are clearly not audiophile speakers, but they are a terrific value for the money. Portable and undoubtedly better than the usual cheap desktop fair. For the money, I think these are hard to beat.
Let us know what you decide and how it works out.
-- JBGood
Posted on: 25 September 2009 by winkyincanada
Have you thought about a nice set of headphones? Depending on your living setup, it can be nice not to disturb others whilst working away on the 'puter. It also helps when you "accidentally" find yourself on a website your other half might not appreciate Winker.
Posted on: 28 September 2009 by Skip
nSats sound best in the near field. I would go for that if I could possibly swing it, even second hand.
Posted on: 28 September 2009 by kev 1966
Scotty,
Audioengines are very good the 5s are superb, I was tight on budget at the time and ended up with Samson Studiodock active set up very good value for money..
Hope this helps
Kevin
Posted on: 29 September 2009 by scottyhammer
Thanks guys
