Axent / Axess Centre
Posted by: Martin C on 06 January 2009
What happened to Axent and Axess? They are out of production? Just have the urge to look for one to replace my Trikan, heard it's much better match to SBL.
cheers
Posted on: 07 January 2009 by tonym
Sadly, they're no longer made. I've got an Axess, which is a superb Centre speaker (the Axent's a real monster!)and did indeed match my old SBLs very well.
Id suggest second-hand but I suspect you'd struggle to find a pre-owned one.
Might be worth trying an n-Cent?
Posted on: 07 January 2009 by Stuart M
Or you could use a single SBL as your centre, works well for me.
Posted on: 07 January 2009 by Manu
Horizontal?
