I'm a sad puppy.... or 'whats the best tweak you have done for least money?'
Posted by: andy c on 12 September 2003
OK,
so I lead a dull uninteresting life apart from my stereo... lol
I was sat listening to it today, and then realised I'd not stuck the bottoms of the picture's on the walls to the walls with blu-tac. I read about this whilst in my old house, and it did have a little improvement in treble clarity. I've just done it and its had the same effect!
My ears are playing tricks again me thinks.. or I've finally cracked up!
so, whats the most cost effective tweak you have done?
Posted on: 12 September 2003 by Laurie Saunders
Mentioning the most cost effective upgrade is prohibited on this Forum. Total cost...less than £1. I`ll leave you to work it out
Laurie S
Laurie S
Posted on: 12 September 2003 by syd
£3 for two concrete slabs from homebase under the Briks was a remarkable improvement on my suspended floor. It might not work for everyone but it was night and day in my sistem.
Yours in Music
Syd
Yours in Music
Syd
Posted on: 12 September 2003 by plynnplynn
B&Q slabs under the speakers.
Terry
Terry
Posted on: 12 September 2003 by liam
blu-tak behind pictures?
does it really work
does it really work
Posted on: 12 September 2003 by Alco
The best VFNM (Value for No Money
) tweak I recently did was:
Plugging the mainscable from my amp directly into the wallsocket, instead of plugging it in one those el cheapo mainsblocs I used for many years!
regards,
Alco
regards,
Alco
Posted on: 12 September 2003 by hi fi fo fum
Hard wire my amp right to the fuse box, # 8 wire for fuses
.....Geofiz, were are you
Posted on: 12 September 2003 by Tarquin Maynard - Portly
Shut all the doors and windows.
Disconnect and reconnect all plugs/interconnects. Two for the price of one.
Try them.
Mike
On the Yellow Brick Road and happy
Try them.
Mike
Posted on: 12 September 2003 by Manu
Me, walking from room to room.
Room 1: Serie 5, Intro.
Room 2: CDX2,202,282,200,250 Allae or SL2.
Room 3: CDS3,252,300,NBL.
Walking cost nothing.
Emmanuel
All opinions are my own, and reflect those of the organisation i work for, even if not stipulated.
Emmanuel
Posted on: 12 September 2003 by Steve Toy
Removing all clutter (stuff that may rattle or resonate in some way) from my listening room and covering the mirror on a dresser with a towel. I suppose the mirror (and dresser) could have been removed but the towel upon it seems to work, and keeping funiture in my room that doesn't resonate deadens the sound nicely.
Steve.
Steve.
Agree Steve.
A no cost tweak: Borrow a subwoofer and play it loud in you listening room, fix or remove everything that rattles.
Emmanuel
Emmanuel
Manu,
Thanks, but I don't think I'll be permitted to remove stuff that will surely rattle outside of my listening room, notably in rooms downstairs.
My speakers go quite low as it is, so the sub would have to be pretty hefty.
Steve.
Steve.
Posted on: 13 September 2003 by prowla
Sent the wife & kids out.
Paul Rowlands
Paul Rowlands
Posted on: 13 September 2003 by Rasher
Go to the local dealer and hear the best system they have in the shop, then go home and hear your own system, set up and sounding good in your own room. Then phone the shop and tell them that your system is better than theirs.
The blu-tak behind the pictures is a great idea. I will do this tonight. It's so obvious really.
Posted on: 13 September 2003 by plynnplynn
Originally posted by Alex B.:
Do concrete tiles really help? If yes, what exactly do they do? Give you more bass but loosing a bit of mids and treble or taking away booming bass and tightening it to a clearer bass? I have a thick carpet too and am now putting pucks underneath the spikes as they are going thorugh the carpet into the laminat floor.
A young grasshopper seeking help from the wise NaimNiacs with his Mullet sistem
IMHO concrete slab, marble slab etc tightens bass - lose nothing.
Those of you who enjoy reading techy stuff and have devoured Vance Dickason's 6th Edition of 'The Loudspeaker Design Cookbook' will have noted that he mentions that "A new technique seen in the marketplace consists of providing some type of energy 'sink' for the enclosure to rest upon. This takes the form of a heavy stone or marble platform which simply does not vibrate in any fashion and cannot transmit vibration to the floor."
Terry
Terry
Posted on: 13 September 2003 by ken c
funny, i have blutac behind pictures in my office not for sonic purposes, but to allow me to adjust them straight. i suppose i get the sound quality benefits for free...
one of the most significant teak i have tried is to re-arrange stuff in my office so that for example, the cd rack wasnt too close to one of the sbl's (in fact i got rid of heavy cd rack altogether). further freeing space around the speakers has also brought about some benefits.
enjoy...
ken
enjoy...
ken
Posted on: 13 September 2003 by billyj
Hey man,
This is called the £4 upgrade. You place a £1 pound coin under each spike of the hifi rack, and it sounds great. Honest.
If you have a tripod its a £3 upgrade.
Give it a go, good luck.
BillyJ
PS The ear syringing is also good and free from you local GP/Nurse.
BillyJ
Posted on: 13 September 2003 by Andrew Randle
I'm blowing a fuse trying to work that one out.
Andrew
Andrew Randle
Linn Binn Sinner
Posted on: 13 September 2003 by Martin D
Undo the locking ring on interconnects - carefully - try it it works - have to thank Doug for that one. I didnt think it would work - I was wrong!
Martin
Martin
Posted on: 15 September 2003 by Martin Payne
Billy,
this tweak has never worked for me.
cheers, Martin
E-mail:- MartinPayne at Dial.Pipex.com
Posted on: 15 September 2003 by Rasher
Best free upgrade by far is board pulling
Posted on: 15 September 2003 by Tim Jones
1. Nail a rug, throw, or similar big piece of material to the wall between your speakers. Gave deeper bass, cleaner mid for my SBLs.
2. Scrub the contacts on your mains plugs with Brasso. Works a little bit.
3. (Especially turntable users and M*n* owners) Make sure your racks and boxes are dust-free. M*n*, in particular, gets very dusty over time. It really does seem to make a difference to the sound.
PS Hope forum members aren't going to waste the valuable time of GPs and practice nurses by getting their ears sysringed for no good clinical reason...
Tim
Tim
Posted on: 15 September 2003 by andy c
Hi,
Re the Tim Jones comment about putting a rug up etc....
I shut my vertical blinds in my living room when doing a serious listening session - seems to free the treble up etc (obviously the reflections are not getting through to the window to be bounced off). Only problem is it goes dark!
Andy -
I guess there's a balance in every room. The more beanbags, rugs, sofas, learned tomes, voluptuous people, etc you have in a room the less 'zing' (i.e. reflections) and the deeper the bass, more focused the sound.
But if you go too far, the more subjectively 'lifeless' everything will sound.
The key thing may be to decide how to achieve the ideal balance for you and then to keep the room tidy in that context, because (as someone said earlier) the tidiness of a room has a definite effect on your perception of the music. That's why leaving old plates and cups, tissues, fag butts and beer cans all over the floor doesn't really count as 'room-damping'.
Or does it...
Tim
Or does it...
Tim
Tim,
LOL
Totally agree re room layout - furniture etc, especially large sofas etc
LOL
