Snaps query
Posted by: redeye on 30 December 2003
Will a Snaps power a Stageline? Or a Headline for that matter
If it makes a difference the Snaps is circa 1982.
Happy New Year to y'all
Posted on: 30 December 2003 by Chris Murphy
Big Red,
That amp looks good. I have it with me now and will recap it and send it on. I can adapt the Snaps to have a 5 pin socket if you require. It will then power other more modern stuff.
Chris
Posted on: 30 December 2003 by redeye
Yes please Chris. That'd be cool Smile
Posted on: 30 December 2003 by Manu
Yes a SNAPS can power a Stageline with the dual rail mod.
Yes a SNAPS can power a Headline as is but it is easier with the 5 pin Din. You will need a SLIC cable, it is a single rail cable but comes standard with a 5 pin Din. You will have to pay an extra to change the 5 pin Din for a 4 pin, so make the SNAPS moded.
Emmanuel
All opinions are my own, and reflect those of the organisation i work for, even if not stipulated.
