Hi
Here are the results of my power amp trials.
The 3 power amps were: 1. NAP250, old style, fully serviced; 2. 640 Crimson Monoblocs, couple of years old, checked over; 3. Dynavector HX1.2, old spec so less power than new, checked over.
Costs new: 1. £2000, 2. £1400 the pair, 3. £4000. Cost s/h/ex-dem: 1. £730, 2. £900, 3. £1500.
Again, I will attempt to score meaningfully out of 100.
I do not mark 135s out of 100 here but I know them well enough so I refer to them in the conclusions. I’ve heard a NAP500 a couple of times and refer to that too.
First the unscientific part: Mains quality has just improved relative to the preamp trial. Not every power amp was tested with every preamp.
Supports were Base. Cabling was Naim, Chord, Linn and DNM. Everything was given 48 hours to warm up.
So:
1. Power, Grip, Authority: 250, 6; Crims, 8; DV, 9
2. Pace: 250, 8; Crims, 9; DV, 8
3. Dynamics & Scale: 250, 6; Crims, 7; DV, 9
4. Timing: 250, 8; Crims, 8; DV, 8
5. Transparency, Clarity: 250, 6; Crims, 7; DV, 9
6. Bass weight: 250, 6; Crims, 7; DV, 9
7. Bass definition: 250, 6; Crims, 7; DV, 9
8. Handling of Transients: 250, 6; Crims, 7; DV, 8
9. Imaging & Sound stage: 250, 6; Crims, 8; DV, 8
10. Musicality & Enjoyment Factor: 250, 7; Crims, 7; DV, 9
This gives the following totals out of 100: 250, 65; Crimsons, 75; Dynavector, 86.
Conclusions:
They are all good amps. The 250 comes out well for a very old design. The Crimsons are shockingly good at the price and are super fast. They are let down by a lack of sophistication and would probably be just pipped by a pair of 135s, but not in every system. I regard 135s as a sophisticated and more musical version of a 250, clearer and with more grip; same species though, they would score about 76. This is an old spec HX1.2 the newer one is even better. To my mind a NAP 500 would score about 90. A new HX1.2 would probably score about 90 as well.
Alex
Posted on: 10 November 2001 by Top Cat
...that the reason there is no picking up of individual instruments, etc., is that there is precious little control over the acoustics, and the priority is 'quantity of sound' over 'quality of sound' for most amplified gigs. For instance, I've been to a few hundred gigs in my time but nothing has ever come close to the sound quality I get in my living room, and I'd hope the same would be true of other members' systems also.
I think the 'dynamic' is a product of weaknesses in other areas of the amplified gig. Sure, it's louder and everything is so much more packed with energy, but the environment and acoustics of such gigs is rarely able to contain that sound and it invariably sounds really crap.
I'd know I'd have gone wrong if I got that sort of sound in my living room - gigs are enjoyable because of the atmosphere, the 'liveness', the interaction with the crowd and the sensation of the event - all good things that make a gig enjoyable DESPITE the sound, which you put up with for the sake of the other qualities.
Anyone wanting gig sound would be far better advised buying a Peavey rig and a mixing desk, one speaker turned all the way until it honks on its one note bass, and pumping up every slider to max. Guaranteed gig sound, and no NAP500s in sight...
TC '..'
"Girl, you thought he was a man, but he was a Muffin..."
If (as I understand it) the 135s are simply monoblock NAP250s, then I'd still expect the 640Ds to blow them out of the water, although perhaps to a lesser extent.
However, I haven't done a comparitive demo, so until I have I can't say for sure.
All I know is that there is a performance gulf between the 250 and the Crimson 200w monoblocks (and I have done a demo with new latest-spec versions of each very recently) with the Crimsons 'out-Naiming' Naim on the PRaT and enjoyability, whilst having significantly more grip and control (I mean, seriously, did you expect anything else? A comparison with the 135s is therefore much fairer in this regard).
The interesting point to note is that I have found (like quite a few hifi components) the Crimsons do take a while (2 days+) to come onto song - but this variation is only small.
I think the fairer comparison would have been the 100w Crimson 630s versus the 250, the 135s versus the 640s - and I'd still back the Crimsons, unless the 135s are MUCH MUCH better than the 250 is.
But seriously, folks, we'd be comparing a pair of four grand monoblocks against a pair of fourteen hundred quid monoblocks - a David and Goliath situation, eh? Stick a DNM preamp on the Crimsons and watch them crucify all comers!
TC '..'
