New Ladder To Climb
Posted by: maserluv on 05 November 2002
Hi Guys,
If 112/150 is more of everything from the nait5.... then wat is 202/200?
Is there any different in sound OR every model is 'more of every thing' than the junior model??
New Range Ladder -
nait5
112/150
202/200
282/250
252/300
552/500
Am i correct??
Wayne
Posted on: 05 November 2002 by NB
The 202/200 is the new version of the 102/180!! a step up from the 112/150.
You are basically correct but what about the effect of the power supplies and how does that effect your ladder. For instance is a 202/super/200 better than a 282/250?
Plenty of listening to be done I think!!
NB
Posted on: 05 November 2002 by Roy T
A new "Stairway to Heaven"... please discuss at length.
"Heaven" is a 552/500 then??
I could live with that!!
NB
Posted on: 05 November 2002 by maserluv
That is not the 'Heaven'.
552/500 is top of the ladder, the 'Heaven' is in the software!!!
Some people can see the 'Heaven' already even though they are only at the nait5 level....
It's in your mind dude!!!
NB
Wayne
Posted on: 06 November 2002 by Roy T
Using the upgrade ladder described by Wayne;
Calculate the money required to reach your desired upgrade?
If this money were used to purchase software how many items could you purchase?
What would give you the most pleasure?
(a) Playing both your old and new music on existing kit.
(b) Playing only your old music on new kit.
(c) Buy some new software and save some cash for the new NAT.
You don’t have to share your answer with the forum, you just have to think about your answers.
Posted on: 06 November 2002 by jpk73
CD555, 552, Snaxo5-5, 3*500 > DL2s
...plus all the new PSUs and of cource the new LP55!
As for multi-channel: buy some more 500s and use your now obsolet DBLs as active rear-channels etc...
- Jun
