AV2 RS232 control protocol ?
Posted by: Roy Donaldson on 25 July 2009
Hi there,
I'm not sure if I've seen this anywhere before, but is the RS232 control protocol that the AV2 / DVD5 use to communicate with each other been ever published before ?
If not, anyone know how to go about obtaining a copy of this ?
Thanks,
Roy.
Posted on: 25 July 2009 by karyboue
The units communicate via Ethernet, not RS232.
The RS232 input is to link to a computer for the upgrades I guess.
Posted on: 25 July 2009 by james n
It uses RS232 for multiroom control and integration.
Roy i used to have a link to the codes which used to be on the NANA site - can't find them now as the site has changed. Worth asking David Dever as i'm sure he'd have the info.
JAmes
Found it again
control codes
James
