Ittok setup questions
Posted by: Mekon on 19 April 2003
I've just had an Ittok (& DV 10X5) fitted to my LP12. Sounds great. Only problem is, after getting home, I realised that the arm height is set so low that the arm lift doesn't lift sufficiently. I've never been great at manual cueing, and I would be useless if beer entered the equation. Is it something I could adjust myself to save the palaver of traipsing down the dealers? I am eyeing that grub screw, as I'd guess thats how I could loosen it. I am utterly hamfisted, should I leave it alone?
Also, any ideas on best settings for the DV? The dealer suggested that both dials at 2, and just to balance (more difficult than I thought) the arm with the counterweight. Initially it was set at 1.9 (recommended range is 1.8 - 2.2). but it jumped out of the groove on a widely spaced EP.
