Recording off-air - time-limited
Posted by: Chris Metcalfe on 05 August 2001
My most pressing problem this summer, apart from not having enough time to visit all the excellent restaurants and pubs in Norfolk and Suffolk (amazing lunch in Burnham Market), is how the hell do you record long-ish radio programmes (specifically the Proms) - two to three hours and you're out anyway? What a waste of a NAT02.
All the recording hardware seems limited to about an hour. Someone once told me you can hook up the hifi/tuner to a Nicam VCR, but I've no idea ho you would use the tuner in this configuration, or how to connect. Is this feasible, is the sound OK, or are there alternatives?
If you want it to sound good (and it bloody can !), use higher recording speeds, say 9,5 cm/s at least, and buy a fully revised machine of decent quality - check the other recent threads about that topic.
Cheese - may all beings be happy ![]()
In a nutshell.......try looking at Revox reel to reel tapes. They are being maintained by a cottage industry and you can pick up a good working model for about £300.00. You can pay less than that but the quality suffers.
Have a surf on the net......there is loads of info.
I have just ordered a CDS2, but once the wife has calmed down, I may well treat myself to one. The sound by all accounts is brilliant.
Mick
PS Cheese my apologies for repeating you but we wrote at the same time.
quote:Too bad that I'm not Mr Pig - would have been the starting point of another funny clash
Two ways: first is a program called TotalRecorder for recording streaming audio over the 'net. It grabs the data stream directly, so is pretty good at avoiding breaks when net traffic is bad.
Second, is to use the line input on the sound card to record using something like the CooEdit application.
Either of the above, you can save to wav file, edit the file to fit on one or more CD's, and write to the CD's - assuming you have enough HDD space for the audio data.
Just a thought. The URL's are:
TotalRecorder
and
CoolEdit 2000
Chris L
Give it a try.
Stuart
It's always a nice day for it, have a good one ![]()
Steve
they do work perfectly on most music recorders.
Also, some DAT recorders have built-in timers; others can be controlled by a remote harwired device (a computer, for example).
-- Pierre Isabelle
When we had parties I copied a few party tapes onto a single half speed 8 hour video tape and the quality was OK (not great but OK).
One of the big advantages with a VCR is that it's already got a timer.
One other thought, current minidisc recorders have got a long play facility, I think the quality isn't supposed to be great but they're small and cute.
Phil
Stephen
[This message was edited by Stephen Bennett on MONDAY 06 August 2001 at 10:44.]
I think my open-reel tape deck sounds better though.
The tuner on my secondary system takes its signal from NTL.
I find that I only get a stereo signal some of the time. Do you get yours all of the time.
Mick
I know you already have a fine-sounding HiFi VHS - this is a cheap (as you already have it) and effective solution.
Just hook up the VHS on a tape loop from your 52 (IIRC)... select TUNER (or applicable input for your Tuna) on the red record out row... set the VHS up to timer record from the input that the signal comes in on from the pre-amp. It might be "SCART1" or "EXT1" "EXT2"... bob's your nearest living aunt. Oh, remember to select the station on the Tuna you wish to record.
I have used this on occasion, and cannot tell the difference between the recorded tape, monitoring off-VCR on the loop, or the tuner input - and all this via a crappy DIN-SCART cable I made up using (horrors!) CAT-5 cable. I think the CAT-5 ultimately thins out the bottom-end, but with the state of most VHS decks this is no bad thing. Certainly good enough to listen & enjoy, and on occasions, keep or transfer to another medium.
So as you can see, it's a "piece of wees" as we say back home. Give it a try and let us know how you get on.
Rico - let them eat Kans.
Not sure Mick - I only record Radio 4. I'll check.
Stephen
As far as Reel-to-reel goes, I'm sure it's brilliant but I really need a timer-friendly machine (plus good ones are expensive). Mick - I thought you were happy with the CDX (?!).
The DAT or Minidisc are possibilities but obviously I don't like the idea of risking quality-loss. For the same reason I wouldn't currently consider a PC or Cable-based solution.
The one question which no-one seems to be able to answer is - why were cassette decks (the main hifi recording medium for 20 years) ever fitted with timers?
