Inputs on 52
Posted by: Carl Leermakers on 03 February 2004
Just installed my "new" 52. Don't want to bore with how good it sounds (but it IS amazing isn't it, this morning I just realised that when a drummer hits a cymbal hard, the sound of it will fade out only very slowly, whatever the rest of the music does ... and that I never heard an amp do this correctly up to now).
Anyway, may I please bore the forum with something more close to earth:
52's inputs are labelled (in order) Tuner/Phono/CD/Tape/VCR/Aux (at least on mine they are)
I have to keep both inputs 2a and 2b free for the Prefix, so says the manual, so I plugged CD into input 3, but what am I supposed to do with my Naim tuner? Get BNC plugs for it? Input 1 ("tuner") is BNC. Inputs 4 to 6, if I understand correctly, have record facilities and I understand from this forum this means they are less 'clean'.
Even if a previous owner of the 52 changed the order of the input labels, the problem is the same: if I have to keep inputs 2a and 2b free for prefix, I only have one DIN input left without recording faciities, right?
