Silly Question Really.
Posted by: Km on 29 December 2002
Hi,
I've been looking through the forum but couldn't find what I am looking for.
How do I turn the Logo off my 102 & 180 ( I don't have the remote).
I suppose easy solution is to buy one. Or, I'll be (hopefully) getting CDX soon so will the remote on CDX has display buttom that works for 102 & 180?
Best Regards & Very Happy New Year,
Km
Posted on: 29 December 2002 by silklee
Originally posted by mad max:
Hello, you still wont be able to turn off the logo's on your pre-amp or amp, Naim does'nt offer that option on their pre-amps and amps, your only able to do that on the cd players!
Max eek
You mean i can turn off the logo on my CD5? How do i do that?
Posted on: 29 December 2002 by onlythat
The logo is the green thing that says "NAIM". You may turn of the display on the cd players-- that is, the tscreen that gives you track info etc. You my not turn off the "logo" on any NAIM gear.
Posted on: 29 December 2002 by Lightkeeper
KM !
Really !
Unplug your power chords.
Ozren
- The difference between Theory and Practice is much greater in Practice than
it is in Theory. -
Posted on: 30 December 2002 by Km
I just thought if you leave your amps "on" all the time like most of users, then surely this should be an option.
Best Regards,
Km
Posted on: 31 December 2002 by Rockingdoc
Not a silly question.
Over Christmas I have de-camped to sleep in the music room at home, to accomodate guests. On the first night I was astonished how much light came from the combined logos of my eight Naim boxes. Had to turn off the power to get to sleep, and then had to put up with it sounding crappy for most of the following morning.
Switched logos would be nice (I have them on my Crown amps), but probably wouldn't get past the bean counters at Naim.
malcolm
Posted on: 31 December 2002 by Mick P
Malcolm
Drape a cloth over them.
That way you go to sleep and your units stay warm.
Simple really.
Mick
Posted on: 31 December 2002 by Bosh
"Drape a cloth over them" - does this stop the transformers chirping too big grin
Posted on: 31 December 2002 by Adrian F.
Some power-amps turn off their logos when they overheat (check your manual). But this is something to avoid red face
So don't forget to take away your anti-light and anti-humm blankets befor you turn music on again... big grin
happy listening
Adrian
