Options to connect AV to main system - 2 channel
Posted by: P.Bonte on 28 April 2009
Hi,
I recently connected my main system NAC202,NAP200 to my AV system.
The connections are :
DVD player - coax digital
Airport Express - optical digital
Digital TV - optical digital
VCR - analogue out.
All is connected via an old AV amp and fed in 2 channel stereo to my NAC202. This works rather well but I look for other, possibly simpler options.
My needs are analogue and digital inputs (24/96) and simple 2 channel output.
A find left me confused, I do not want multichannel and look for a cheap and simple solution.
Any hints ?
Philippe
Posted on: 28 April 2009 by Former member
If its just good 2 channel you want.
Try a good Dac for your digital inputs and dump the old av amp.
Posted on: 28 April 2009 by P.Bonte
Thank you munch,
Any ideas for a good dac with at least one analog input too and connecting 2*optical and 2*coax and one USB ?
Philippe
